oscarwithC's Avatar
oscarwithC oscarwithC is offline
Car: BMW E46 325i
Default Please help! N54 Boost not on target (No leaks i think?) Logs included - 09-09-2020, 01:17 PM
Hi everyone!
Recently i started to notice that my fuel gauge JB4 boost hijack was maxing out at around 10-13psi at WOT when i am use to see it around 14-16psi.
The car is a 2008 E90 335ix 75k miles with only a JB4 on Map 5 with in this case 20% E85 and the rest 91 octane (Swedish 95 octane)
All logs are 3rd gear pulls except one which includes two 3rd gear pulls and one 4rth gear pull at the end.
I would be so gratefull if someone could take a look at my logs and se what the problem could be!
/ Oscar from Sweden
Default 09-09-2020, 07:27 PM
Log files are massive.
Enable 6 cyl timing
Relog just 3rd gear, I don’t need to see the non WOT portions
oscarwithC's Avatar
Car: BMW E46 325i
Default 09-10-2020, 11:32 AM
Enable 6 cyl timing
Relog just 3rd gear, I donít need to see the non WOT portions
Hi! These logs should be better! Map 5 3rd gear 20% ethanol
Default 09-10-2020, 03:55 PM
Looks like you have a pretty sizable leak. 7-8 psi under target.
I'd visually look for a boost leak, it looks pretty massive based on the logs.
oscarwithC's Avatar
Car: BMW E46 325i
Default 09-11-2020, 12:32 AM
Ok, thats wierd because i had low boost for a couple of days and once i reset all the JB4 values to stock i did a pull and i was hitting just over 16psi but that was just one pull and it was before i made these logs which makes me think its related to JB4 settings? Could that be the case? for example the FF value went to 150 after these latest pulls, any settings i could try out? Will check if i can se anything visual that might cause a boost leak.
dmckmc dmckmc is offline
Car: E60 535i
Default 09-11-2020, 01:13 AM
wgdc is maxed and stays at 99 with throttle at 100 percent. this is an indicator of a boost or vacuum leak (be sure to check vacuum lines). ff adjusting to 150 is not the cause of low boost, it's the result of trying to raise boost
N54
FBO
E40
JB4
MHD
XHP
Default 09-11-2020, 05:08 PM
FF learning back up to 150 is a sign of a boost leak somewhere in the system.
