(#826)
hankweed012 hankweed012 is offline
Car: 2017 C43
Default 10-30-2019, 10:04 AM
Originally Posted by Darkraybans
The install guide link in the starter post is "404 not found" for me. Is there another link I can try?
https://www.n54tech.com/instructions...400_stage1.pdf
Here you go my guy
Car: 2017 C43
Default 11-08-2019, 05:21 PM
Hey Terry,
I looked through the whole post to find instructions on where to locate the fuel sensor to attach the green wire. Can you upload instructions on where its located? thanks.
Default 11-08-2019, 07:19 PM
There is a photo around here somewhere, I'll see if I can find it.
Soobahru Soobahru is offline
Car: C43 Cab
Default 11-08-2019, 11:43 PM
Hi Terry,
Finally got to do a few pulls for you to check out before I move onto map 2.
Thanks in advance!
-Marty
Default 11-09-2019, 10:41 PM
Looks good to me, go for it!
Sheddy Sheddy is offline
Car: 2016 Lexus IS200t
Default 11-10-2019, 08:11 AM
Hey Terry,
My brother had a Stage 1 on his 2017 GLC 43. He recently took it to the dealer regarding a buzzing sound from the engine bay. They replaced the boost pressure control (pressure transducer). When we tried reinstalling the Stage 1 we are getting a CEL. Is this the same as the SENT pressure sensor?
Default 11-10-2019, 09:00 AM
They won't change the sensor type.. Maybe an issue with the Stage1 board itself? Good time to upgrade it to a JB4.
Default 11-10-2019, 05:35 PM
Will upgrade to the JB4 and keep you posted. Thanks
Car: C43 Cab
Default 11-11-2019, 09:29 PM
Uploading Map 2 tonight. very excited to see what becomes of it.
What values should I be looking for? Excuse my ignorance. I am coming from the world of subarus and there I was looking for knocking and boost creep.
Thanks in advance Terry.
-Marty
Savvy Savvy is offline
Car: C300
Default 11-12-2019, 01:55 PM
Hey Terry,
Heres a pull on map 1, I was wondering should I go straight to map 2 from here or mix in some e85 first?
Thanks,
Car: 2017 C43
Default Today, 04:08 AM
Hey Terry, Ive been noticing quit a bit of power inconsistencies. I Feel like my car had better race times without the JB4 because of the throttle/shifting issues.
1. Car cuts off the throttle as shown in one of the logs.
2. Also the Car pulls hard while approaching redline then shifts and right after the shift the car loses much of its power then starts taking off again. Its almost like a lag, Its a rough upshift (WOT) then right after hesitates a bit then takes off again. If you look at the RPM line in the logs, instead of the RPM climbing again it goes flat for a moment then starts to rise again almost like a U shape instead of a V. I do not notice this when I put the car back to stock Map 0.
Can you tell me what could possibly cause this and some potential fixes? I read up on the BMW forums and many other JB4 or JB+ users experienced this. Some found a fix using the newer firmware and some did not. Ive posted a few logs here. let me know what you think.
Running Map 5 with E30 Fuel. In sport+ mode. 2017 C43
