(#576)
Default 08-18-2019, 04:48 PM
You'd need a JB4 mobile blue tooth adapter and the JB4 mobile app, they are $170 combined.
Dpas1973 Dpas1973 is offline
Car: 2019 raptor
Default 08-18-2019, 04:50 PM
i got the data cable only for my macbook. was wondering if i have to download an app to switch the programs
Default 08-18-2019, 04:53 PM
Oh, the data cable software is free and posted in the first post for windows. Mac software should be in here somewhere: JB4 Mobile - N54Tech.com - International Turbo Racing Discussion
Car: 2019 raptor
Default 08-18-2019, 05:04 PM
couldn't find anything on macbook software there
Default 08-20-2019, 10:22 AM
Bottom of first post: JB4 Mobile for Apple and Android Smart Phone Support - N54Tech.com - International Turbo Racing Discussion
You'd have to ask any follow up question there as it's a 3rd party software. I've never used it.
icecoldak's Avatar
icecoldak icecoldak is offline
Car: 2018 F-150 Limited
Default 08-28-2019, 09:42 AM
Terry just installed a used JB4 in my 19 Limited (I had around for a year lol) and granted I have not downloaded the connect app yet--basically I just wanted to check it out real quick, But withen a few starts/drives it throws the P0236 code "Turbocharger Boost Sensor A Circuit Range/Performance" and pretty much the truck cannot get out of its own way lol....
Abyssf150 Abyssf150 is offline
Car: 2019 f150 2.7 Ecoboost
Default 08-28-2019, 09:47 AM
I recomend down loading the app. I updating to the latest firmware and seeing what happens.
Default 08-28-2019, 11:10 AM
That sounds like a wiring issue to me. email in install photos to support@burgertuning.com. Did you open the enclosure at all? Sometimes customers knock a wire loose when doing the JB4 mobile attachment so double check all wires in there too. Maybe send a photo of the board in as well.
icecoldak's Avatar
Default 08-28-2019, 11:19 AM
Ill open it up and check, I got it used and he said no issues with it---I hooked it up just like the instructions said Brown wires to front sensor and rainbow to the rear....Ill send you pictures as well!
2.7Boosted-Brad's Avatar
2.7Boosted-Brad 2.7Boosted-Brad is offline
Car: 2018 F-150 2.7
Default 09-02-2019, 06:02 PM
What user adjustment settings do you recommend? Do they affect all maps? Trying to track down underboost conditions?
WOOSH!
Default 09-02-2019, 07:05 PM
Normally nothing needs to be changed, other than reducing boost in 1st gear if you need it.
Car: 2018 F-150 2.7
Default 09-02-2019, 07:47 PM
What are the default settings or what do you recommend?
WOOSH!
Default 09-02-2019, 08:02 PM
They are all zero other than boost safety which can be set to say 21psi for more, little higher for those really pushing things.
yellowssm yellowssm is offline
Car: 16 BMW M4
Default 09-06-2019, 05:46 PM
I traded my raptor in and gave my buddy my jb4 but he canít Get Bluetooth to talk to phone. It says kit not owned. How do I get past this?
Default 09-09-2019, 10:13 AM
Email them, as it says to do
Support@Jb4connectkit.com
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 09-17-2019, 12:24 PM
Removed JB4 for 3 weeks, no issues.
Installed ECO 7 update yesterday. CEL just popped up now.
335imofo's Avatar
Car: 335i Coupe
Default 09-19-2019, 05:06 AM
Update: I went to read the codes this morning, plugged in ODB cable and mysteriously the CEL went away when i looked back up. I dont get it.
Default 09-19-2019, 10:23 AM
Could just be when installing the JB4 system when the ecu still wasn't asleep.
Simple tmap/map codes or something.
Default 09-24-2019, 05:12 PM
What was the specific code? Unplugged things can cause a temporary CEL that will clear itself if battery isn't disconnected and car wakes up.
335imofo's Avatar
Car: 335i Coupe
Default 09-24-2019, 07:10 PM
Seems to be good now. Day 3 no CEL.
trunks33 trunks33 is offline
Car: 2018 Ford Raptor 2016 Corvette Z06 7speed
Default 11-07-2019, 12:27 PM
Hey Terry, can you please check out these logs. Are they ok? I have 2 logs from Map 3 and 2 from Map 5. I am running a 93 octane gas. S&B intake, turbosmart BOV, borla attak exhaust.
Thanks,
Arthur
Default 11-07-2019, 05:17 PM
I can see fuel pressure starting to drop here especially on map5, so map3 is probably a better fit for your truck.
Default 11-07-2019, 05:31 PM
Great thanks!
Hammmerhead Hammmerhead is offline
Car: F150
Default Yesterday, 10:51 AM
Is the speed limiter removed with the current JB4 tunes?
Is the transmission changed also doing away with the skip shifting on the 10 speed?
