(#426)
Default 09-22-2019, 04:23 PM
You probably have a V1 system that doesn't have the integrated BCM connections so there won't be a ground wire. The ground is part of the BCM.
Newn63 Newn63 is offline
Car: 2012 550I M Sport
Default 10-30-2019, 10:24 AM
We try to give the N63 a little attention. Still waiting for customer logs on the new firmware that was posted a couple weeks ago.
Terry,
Are you looking for any logs in specific? Normal driving,wot. Any specific map? 1,2,5 or 7?
Default 11-01-2019, 07:58 PM
Hereís a few logs
Default 11-01-2019, 08:40 PM
Originally Posted by Newn63
Hereís a few logs
I think that quoted an older post of mine.
On your logs Map 7 reverted to map0 due to maxed out fuel trims/lean AFR. But map2 looks OK. I'd stick with that.
Default 11-01-2019, 08:44 PM
Sounds good running e30 mix , would map 7 work better with 110 octane? Thanks for the reply
Default 11-07-2019, 10:56 AM
Terry,
Hereís a few more this time with a 40% 110 octane to 60% 93 octane mix.
She feels pretty strong going to the strip tomorrow to get some numbers
Default 11-08-2019, 12:34 PM
Map2 is prob the best fit but give them a whirl at the track and see what works best!
ErinM's Avatar
ErinM ErinM is offline
Car: 2011 550 M-Sport
Default Logging just because - 11-10-2019, 05:04 PM
Havenít been on here in a while. Here is log from a run to the store for the wife today.
How are all you N63s holding up?
KYtuning:Cayman Islands
BDJL BDJL is offline
Car: 2011 550i Manual
Default 11-10-2019, 06:27 PM
A log from Friday.
2011 550i 6MT
Default 11-12-2019, 10:41 AM
Mine is great ran a 12.9 @114 spinning in first and just a little in second so can definitely pull off a better time needless to say I’m happy no mods all stock just the good ol JB4
