(#501)
c0op3r c0op3r is offline
Car: 2017 F57
Default 08-31-2018, 10:58 AM
I got my Package today I decided to install the Bluetooth Module INSIDE the casing. There seems to be plenty of room and it is just safer and better wiring.
I did not use the tap connector (I hate those things) I soldered to the Positive wire on the board and added a connector so the module can be removed with ease.
Default 09-01-2018, 10:41 AM
You know, we've never tried that. Does it work well in car?
Car: 2017 F57
Default 09-01-2018, 11:13 AM
I will let you know in a day or so, the car is at MINI right now getting the JCW brake Kit installed. I am picking it up today, at which time I will install the box, download the app and test it all out and let you know.
Car: 2017 F57
Default 09-01-2018, 06:45 PM
OK So I got the car back with the Brake Kit installed. I installed the JB4 as shown above in the pictures, the box is mounted on the top of the battery and it works perfectly.
So putting the Bt module inside the main box works just fine on the MINI Cooper.
Car: B46 F56S
Default 09-07-2018, 04:56 AM
Is it possible to show meth flow on gas gauge instead of boost? I already have a mechanical boost gauge. Would like to see more meth options on MINI.
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 09-13-2018, 07:30 AM
Any updates for X2 yet?
Still struggling with no dash mode.
Anyone else JB their x2, or am i the only one? lol
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 09-18-2018, 09:20 PM
How much power are the tuned 2.0 putting down?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
