(#1651)
irish222222 irish222222 is offline
Car: F10 528i
Default 08-04-2018, 07:13 PM
Originally Posted by Aekdbrich
F10/535 in dash control
To enable the BC button menu changes on F10/535 models you must connect to the JB4 using a BMS DATA cable or BlueTooth kit and change FutureUseD bit #1 on (resulting value of 2) press save. Then turn off ignition and lock doors for 5 min to allow the JB4 to reset.
*Special Settings For F Series JB4 EWG & PWG version 11+
FUD:
bit0 - Disable in dash BC button controls
bit1 - Alternative in dash BC F10 compatibility mode
bit2 - Disable oil temp warmup protection -- full boost target when oil temps < 160
bit3 - Disable wastegate/FF adaption learning for diagnostic purposes
bit4 - Enable user adjustable progressive meth control
bit5 - Disable port injection mapping tip in gain
bit6 - Enable extra timing cylinder logging
bit7 - Slow down CANbus sample rate - required for some vehicles with older software
FutureUseA: Negative offset to dutycycle via EWG connector to correct for over boost conditions when PWM is low
Loving the JB4 in my F10 528i. However, I can't get the BC controls to turn on and it seems the Future Use D options are not the same as above. My Bit 0 is the same, but I don't have any other Bit option related to BC controls. It would be great to be able to disable the fuel gauge boost gauge and rpm sweep among other things in the BC controlled settings.
Default 08-06-2018, 09:46 AM
Are you on the most updated firmware? It should all be the same for 5 series regardless of engine.
Car: F10 528i
Default 08-06-2018, 02:58 PM
I think so, I'm on the N20_OBDII_EWG_6_T5
N54.Dave N54.Dave is offline
Car: 2009 135i
Default 08-14-2018, 10:27 PM
What map should I run in a 320i while stacking with bm3? map 5 will be the best? Sorta seemed like they were fighting each other to target. Bm3 flash is Stage 2 93. Not sure what to do once I want to run E30 either due to the bm3 only being 93.
Herc Herc is offline
Car: F20 125i
Default 08-14-2018, 11:52 PM
NONE!
Take logs with jb4 at map 0 and then at map 4 and then disconnect ALL plugs and relog again with BM3. Monitor timing mostly and boost targets. Experience showed that JB4 cant stuck with BM3 atm on the N20. If the user Midnight see the post might be able to provide with some depth experience he had recently trying the same thing. He had severe timing issues and was unable to hit target when JB4 was even connected in map 0. We ended to remove all plugs and tune got smoother and more powerful.
Car: 2009 135i
Default 08-15-2018, 10:06 AM
Originally Posted by Herc
NONE!
Great to know! Thank you. Guess I’ll have to wait for terry’s input on backend flash mode
Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default 08-22-2018, 08:23 AM
JB4 Map Guide
Map 0: JB4 disabled.
Map 1: PWG models absolute target 21psi peak, EWG models additive 4psi peak over stock.
Map 2: PWG models absolute target 22psi peak, EWG models additive 6psi peak over stock.
Map 3: Progressive Methanol Injection. Requires BMS methanol kit or BMS FSB for meth pump control.
Map 4: Stock performance, JB4 on
Map 5: Absolute targeting map with a peak boost 17psi. Suitable for 320 & 520 applications.
Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only.
Map 7: Race gas absolute target map. Peak boost 23psi. This is a fairly aggressive map and increases engine damage risk. Use with caution.
Hi Terry, there is something like this for N20 X1 & Z4?
http://www.n54tech.com/flash_files/jb4_wheel_1.jpg
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI - Phoenix Racing CP - TIAL BOV - NGK 5992 - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear bar - xHP stage 3
Ripley's Avatar
Car: 335i N54
Default 08-25-2018, 01:18 PM
Guys, anyone knows?
Menu 0 is for map selection
What about menu 1, 2, 3, 4, etc?
bucketfoot bucketfoot is offline
Car: 2014 BMW X1 28i xDrive
Default 09-02-2018, 06:37 PM
Was running a track event with NASA Rocky Mountain yesterday and ran into something I haven't experience before install the JB4.
During the last couple of laps during two of my sessions (during the the hottest parts of the day) I experienced a fall off in power. I'm guessing this was a matter of the intercooler getting overwhelmed and the JB4 backing itself down to protect the engine. But I'm wondering if others have experienced this and if this theory makes sense.
I had a last run later in the day where it had rained for awhile and really cooled things down. Despite running my fastest laps of the day I did not experience any drop-off in this session, which is a big part of what made me think it was temperature/overheating that was the root cause.
The JB4 is currently the only powertrain related mod the car has.
Ripley's Avatar
Car: 335i N54
Default 09-14-2018, 06:06 AM
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 09-15-2018, 07:58 AM
Hello grooveriders,
Your logs look good except it's a bit lean as AFR is above 13 in high engine RPM.
The engine power cut may caused by the 8AT safe fail protection. ZF 8AT45 can handle maximum 450NM. The car cuts the engine power when it's over 450NM.
Originally Posted by grooveriders
Hi Terry i have been using the jb4 running on map2 for the past few months & very happy with it.
My car is a 520i with upgraded 528i pistons. Running a ER ******* ******** , *** back remus exhaust and stainless steel charge & Boost *****.
Ran a few WOTs on the road with good performance and no check light or issues.
Today i went to the dyno for a run but once the engine goes > 6000+ rpm , there will be a power cut. Power was at about 290bhp 440 torque Nm at around 6000+ rpm.
No check lights from the car though. I have attached the 2 log files. Appreciate your kind advise that what could be wrong.
Car: 2013 Z4 20i
Default 09-15-2018, 08:18 AM
N20 Z4 menu is similar to this.
Have you noticed anything different?
