Loeschge Loeschge is offline
Car: 335i N55
Angry After Repairworks from BMW JB4 does not work anymore - 09-21-2019, 02:42 AM
Hi all,
I had to give my 335i N55 E91 to BMW for a recall. They had to change the main power cable at the power distributor. For that work they had of course to disconnect the battery. JB4 was on map 0 for that works. When I got back my car after one day, it did not start properly and the engine stopped always after seconds. Beside the standard codes for boost it says something like rail sensor short circuit. I can't connect with the JB4 via mobile or laptop anymore. Did they ruin the JB4 Chip? How is that possible? When I disconnect the JB 4 only the JB4 Box, the engine is running good again. Only the Code still stays. I will disconnect the whole cables today and see if the code is disappearing but I don't know how to connect with JB. Is there a way of resetting the box on the hardware?
Car: 335i N55
Default 09-24-2019, 11:21 AM
Yesterday I disconnected everything from the engine an only a error for the pressure and temp sensor occured. I will change it an connect the JB 4 again...
Default 09-28-2019, 12:10 PM
E chassis N55? Loose CANbus wires in ECU box?
Car: 335i N55
Default 09-29-2019, 09:51 PM
Yes, E91 06/2010. The wires looked ok for me. But I have disconnected the JB 4 and have now chenged the air pressure sensor without succes. Same Code. Now I will check the cables. If I get to run the engine wothout JB4, I will connect it again but I have not so much hope...
Default 09-30-2019, 08:27 AM
Keep us posted
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 335i N55
Thumbs down 10-06-2019, 03:54 AM
So I did replace the two pressure-temp sensors without success. I did also demount the auxiliary parts to the right of the engine to check the cables. Nothing found. So now I will give it back to BMW -> they have to find it! I am interested about the cost discussions and responsibilities....
After fixing this I will surly also need a new JB 4
Default 10-07-2019, 08:00 AM
Fingers crossed they can find the issue...
e92 AT 335xi 2.0
Doc Race Kit 6062
