Default 03-31-2020, 11:24 AM
Super easy install, won't take more than 30 minutes for your first time. After that should be 10 mins!
Hazynighthawk Hazynighthawk is offline
Default 03-31-2020, 02:14 PM
Is there a guide ? Or instructions ?
Default 04-01-2020, 07:37 PM
The install guide is on our website.
https://www.n54tech.com/instructions...ep_install.pdf
Default 04-02-2020, 11:08 AM
Iíll take pics on install and make a video my engine bays a bit different than a wrangler!
Default 04-02-2020, 08:30 PM
OK great, post up some photos here and we can add them to the guide also!
yellowssm yellowssm is offline
Car: 16 BMW M4
Default 04-11-2020, 09:03 PM
Does this work with both the 2.0t and 2.0t with torque?
Default 04-12-2020, 08:10 PM
Yes all 2L Turbo motors.
Car: 16 BMW M4
Default 04-17-2020, 08:33 AM
I have a JB4 on my M5, if I order one for the Jeep, can I transfer the bluetooth module from the M5? Basically is it the same bluetooth module for all JB4's?
jeep2.0L jeep2.0L is offline
Car: 2020 Jeep 2.0L
Default JB4 Issue - 04-20-2020, 06:53 PM
Hello,
I installed the jb4 a few days ago. Since then I've had problems with map 1 through map 3. I have attached all of the results including map 0
The JB4 is the only modification that is on my 2020 Jeep Wrangler Rubicon 2.0L.
Any ideas on what could possibly be causing what feels like a cut out while acceleration from 0-60?
Thanks,
Cody McNeal
Default 04-22-2020, 10:36 AM
Originally Posted by jeep2.0L
Hello,
Thanks,
Cody McNeal
What fuel are you running?
Car: 2020 Jeep 2.0L
Default 04-22-2020, 05:19 PM
I got the jeep new, never have put anything less then 91, I'm at 7,000 miles.
Default 04-22-2020, 08:17 PM
If map1 isn't working no need to go up to map2 or map3.
Let's try this next. Set map6 values to 2.0 across the board, and log map6 for comparison.
Car: 2020 Jeep 2.0L
Default 04-23-2020, 05:33 AM
Ok, Iíll try that and report back this evening. Thanks
Car: 16 BMW M4
Default 04-23-2020, 07:53 AM
Brandon at Krazyhouse Customs dyno testing our new Jeep 2L JB4 out on his dyno. Solid results on 93 octane vs. stock and got even better on an E30 mix! Will post the E85 mix runs after we make a few more tweaks to it!
Any updates on E85 map tweaks yet? Excited for this
Default 04-23-2020, 01:21 PM
We have a few customers running E30 without issue but it's still being tested. If you have access pump a few gallons in and evaluate. It should benefit each JB4 map.
209hunter 209hunter is offline
Car: 2019 Jeep Rubicon
Default 04-25-2020, 08:02 PM
Iím having a stutter/hesitation when I first roll into the throttle. Especially when the Jeep doesnít downshift (high load and boost, lower rpm). I have a ******* ********, 3Ē catback and intake. Running 91 octane with a bit of e85 (roughly 20-25% ethanol). Not sure if these logs show the issue. If not, let me know what to log. It seems the actual boost overshoots target boost on initial throttle tip in and turbo spool. And then you feel like timing is being pulled.
https://www.dropbox.com/s/twiiccpa3w...87%29.csv?dl=0
Vinniechin Vinniechin is offline
Car: Jeep rubicon
Default 05-07-2020, 07:02 PM
Couple questions. I just ordered.
I got the Bluetooth feature. We now have to download the app for $28?
Second question. Map1 is for 91 octane and map 2 for 93 and map 4 is for e85 mix?
I want it to be a safe tune with no worries. Can someone help educate me on this?
Thanks in advance.
Vinnie
Car: Jeep rubicon
Default 05-08-2020, 05:46 PM
Anyone?
Car: 16 BMW M4
Default 05-08-2020, 07:10 PM
Thanks in advance.
Vinnie
Yes you need to pay for the app
Map 1 is always the 91 octane map. I donít know about the other maps.
There is a lot of safeties built in to protect your motor.
Default 05-08-2020, 08:20 PM
Thanks in advance.
Vinnie
Yes the smart phone integration is $169 for the adapter and app.
What fuel are you planning on using?
Car: Jeep rubicon
Default 05-09-2020, 05:07 PM
Thanks Terry. I will be running 93 exclusively.
Any guidance would be appreciated.
I run this on my Q50 and this forum should be much busier than it is!
Great product and I will be a proponent for sure.
Car: Jeep rubicon
Default 05-09-2020, 05:09 PM
Thank you! So very much.
Car: Jeep rubicon
Default 05-09-2020, 05:11 PM
93 octane only. And will the app allow me to Data log? I already bought the Bluetooth adapter from you.
Thanks.
Vinnie
Default 05-09-2020, 08:05 PM
Yes the app is for logging, map changes, setting changes, firmware updates, etc!
For 93 octane map2 is likely the best fit but a log will confirm.
Car: Jeep rubicon
Default 05-09-2020, 08:08 PM
Thanks Terry. Once I get it and install I will eventually post a log.
Still breaking it in with 200 miles on it and who knows with the stuff going on when I will finish break in.
I appreciate the quick rely.
