jwon jwon is offline
Car: 535xi '08
Default Pure Stage 2 DD with MHD BEF/JB4 initial log - 04-23-2019, 09:01 AM
Hi N54tech,
I got Pure Turbos stage 2 DD installed in my 2008 535xi.
My stock turbo waste gates were shot and replaced them with the pure turbos. Getting the turbos installed were a priority, so supporting mods are still on their way - larger FMIC, ***, and LPFP.
Currently:
5" intercooler
Stock airbox
RB inlets
NGK 95770
Delphi ignition coils
N20 TMap
xHP stage 3 AT.
MAP 6 with Hybrid Turbo recommended settings on this site, BEF PUMP_USA, and targeting 17 lbs of boost.
My Fuel is currently E15 which I'm thinking is safe for now until I get a LPFP as my LPF numbers are in the 60's.
This is my DD and was wondering if my log shows the settings are safe for now until I turn up the boost with support mods.
Best,
Josh
Raginge93 Raginge93 is offline
Car: 07 335i
Default 04-23-2019, 09:00 PM
Logs looks clean. Lpfp in the 60s is okay, 50 should be the worry point.
Default 04-23-2019, 09:26 PM
Originally Posted by jwon
Hi N54tech,
Currently:
5" intercooler
Stock airbox
RB inlets
NGK 95770
N20 TMap
xHP stage 3 AT.
Best,
Josh
Congrats on the turbos
Overall log looks clean- some timing corrections on cyl 3, some more octane would probably clean that right up.
Everything looks safe, wouldn’t worry about running the car like this at all
Car: 535xi '08
Default 04-24-2019, 07:04 AM
Awesome! Thank you both!
Can't wait to get these mods on so I can slowly up the boost.
At 17 psi, car is pretty quick.
THE BEAST's Avatar
Car: 2008 E93
Default 04-24-2019, 09:50 AM
Hi N54tech,
Currently:
5" intercooler
Stock airbox
RB inlets
NGK 95770
N20 TMap
xHP stage 3 AT.
Best,
Josh
I have these on my E93. How far are you aiming to push these in the future ?
Car: 535xi '08
Default 04-24-2019, 03:37 PM
Essentially, I'm targeting around 500-530 whp with a little ethanol in the mix for my DD. I'm guessing that will be around 20-22 psi depending on my fuel. My assumption is that these turbos will be barely breaking a sweat at these power levels.
THE BEAST's Avatar
Car: 2008 E93
Default 04-25-2019, 12:42 AM
At 22 psi you will most likely be a little over the 530 whp mark on a dynojet. Wgdc will be VERY low. At 23 psi I was a little over 550. At 24psi I was 569. Ive gone to 27 psi and thats the most I care to run on the 6AT.
Just to give you an idea on E40 +. Im currently full E85.
Car: 535xi '08
Default 04-26-2019, 06:27 AM
Nice! This gives me an approximation of where I'll be. Thank you!
Is your AT holding up ok? Part of the reason, for me, to keep the boost in the low 20s is the AT and transfer case.
Default 04-26-2019, 06:40 AM
My trans was fine as was my t case running 27-28 psi on my Pure 2 hi flo & 25-28 psi on my doc kit.
Flash the car with xhp if you haven’t yet - just do Stage 3 & possibly an aux cooler to help keep the temps down & you should be alright
THE BEAST's Avatar
Car: 2008 E93
Default 04-26-2019, 12:53 PM
As Dave said, xHP and keep it pushing. So far so good.
