Car: 335i, 2009
Default Turbos on Their Last Leg? - 11-16-2018, 11:10 AM
Hey All, I have been encountering some odd issues in the last 3 weeks, and I could use the expertise of the forum to help shed some light on my N54 engine. I was thinking maybe its a wastegate that's getting stuck, maybe an aging solenoid. What is critical to note, is that the car runs strong and does not have an issue... at the moment.
Issue 1:
Once while driving Pasadena(not like anyone cares), I had very sluggish boost building, kind of like I had no vacuum or you are using Valet mode on the JB4. I turned the car off and turned it on again a few hours later, and the issue has not come back since.
Issue 2:
I was driving a few days later to work (not like anyone cares) and got the code 30FC. I cleared the code, and it came back again. I cleared it again and the issue has not come back since.
Issue 3:
Two weeks ago I was driving up through Box Canyon, and the car had a very loud exhaust sound at low RPM cruising (2k-3k rpm maybe). It sounded as if maybe the exhaust pipe fell off. I reved the engine, and that problem stopped. The issue has not come back since.
The car has been trouble free for quite a long time, and it seems like these issues crept in around the same time. I believe the problems are related, but the inconsistency has stumped me. The car runs strong and I have not had a problem since... What do you guys think?
335i E90 2009 ///M Sport Auto
X5 50i 2013 ///M Sport
BMS Stage 1
