Ghozthunter Ghozthunter is offline
Car: BMW 330i M sport
Default Logs on B46 for review - 01-01-2021, 01:45 PM
Am new to the tuning world and would like to learn more. This is my first time using a jb4 and got some logs starting at 2k rpms on 3rd gear turning off dsc and going WOT (hope i did it right)
This is on a 2019 bmw 330i b46 only mod I have is full CAI kit, temp outside was 55f.
One of the logs may not be done right but ill post it.
I have noticed the sound coming from turbo was louder on my jb+ than with jb4 and more pops from exhaust on jb+ but definitely feel more power now.
Any help will be greatly appreciated.
ckethe99 ckethe99 is offline
Car: 2014 335i
Default 01-01-2021, 01:57 PM
Right now your currently using an additive boost map, the absolute maps are where the magic happens. Logs look ok, but fuel trims are high and are sometimes maxing out, bump your fuel open loop value up from its current 60, to 70 and relog.
Home to the worlds slowest 335i !
2014 335i xDrive | ZF8HP | JB4, MHD w/ BMS E85 BEF, Evolution Racewerks Chargepipe, IC, and DP,
AFE Intake, MPE, and a lot of time on the garage floor!
Default 01-01-2021, 02:09 PM
Thank you, please forgive me for the dumb questions but what is absolute map? I have set it to map 3. Am a newbie I know lol
I have made the changes and will relog.
Car: 2014 335i
Default 01-01-2021, 02:18 PM
You're currently using map 3, which is a additive map, meaning, it takes the boost the factory engine computer is making, and adds a value onto that number. In the case of map 3, its 6psi more than what the factory is making, so if the factory computer was sending 10psi of boost to the turbo, the jb4 will change that number to 16.
An absolute map completely overrides the computer, and the jb4 fully decides the boost, the advantage to this is that it is much smoother.
At some point when you choose to, you can move up to a absolute map provided you have the EWG control wires.
Default 01-01-2021, 02:23 PM
Got it. Thank you for clarifying that. I will purchase a EWG wire for it now lol
Car: 2014 335i
Default 01-01-2021, 02:28 PM
Yup, no problem. Bump up the FOL to 70, and go enjoy your car! Happy New Year!
KnifeEdge87 KnifeEdge87 is offline
Car: BMW G30 520i 2019
Default 01-01-2021, 07:35 PM
It won't do anything on the B series engine
The jb4 for b series doesn't hook into the fuel pressure system
Car: 2014 335i
Default 01-01-2021, 07:41 PM
Thats weird, I remember reading about the FOL adjustment actually working, but come to think of it, your right about there being no fuel interfacing with the jb4.
Default 01-01-2021, 08:21 PM
So its a no go then am assuming lol
Another dumb question coming. Which EWG connector do I order?
Default 01-01-2021, 08:44 PM
The B series one
It might be listed as B58 but it works on b48/b46 too
Originally Posted by KnifeEdge87
The B series one
Ask vipin for deets
VipinLJ VipinLJ is offline
Default 01-01-2021, 10:12 PM
The B series one
Correcto.
https://burgertuning.com/products/n5...arness-adapter
From the drop down menu, choose the one for the B58.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Default 01-01-2021, 10:16 PM
Originally Posted by VipinLJ
Correcto.
Much appreciated. Placed the order just now.
Default 01-01-2021, 11:15 PM
You're welcome. The most difficult part for me was installing it in the JB4! I couldn't get the plastic box to close after. Had to tape it up temporarily and got the metal case instead :D
Current:
Default 01-04-2021, 01:31 AM
Map3 might be a bit too much for the the gas you're using
you have 0 timing advance for a very very long time
If you can get some E85 where you live put some in to get like E30 mix (30% E85, 70% 93AKI)
also
Are you sure you removed the BM3 tune ? It looks like it still might be there. I don't ever remember seeing vipinlj's car (also a B46 330i) having the DME command 20+psi before.
Default 01-04-2021, 01:50 AM
ok sorry i confused you for someone else but couple things
1) going forward do not combine logs and try to make sure each file is one particular run (turn off combine logs), don't manually start the logging, just let the automatic logging (based on pedal position) do it's job (have the log trigger threshold as like 50-60% pedal)
2) go back to map 0 for now, did you buy your car new or 2nd hand? your dme boost target is quite high (your "R4" log) at like 20+psi, that's way higher than any B46 or B48 I've seen. If you bought your car used you could already have a tune on the car.
Default 01-13-2021, 05:19 AM
Was this message meant for me or someone else? Lol
If its for me to answer your question, the car was a demo car and had 2300 miles in it. So technically new I guess.
I received the ewg connector so ill get another log and change the settings like you mentioned. Thank you.
Default 01-13-2021, 05:55 PM
Uploading new log for review using ewg connector. Thank you for the help.
Default 01-13-2021, 10:23 PM
Yes it was meant for you
I'm not sure if you have a particularly hot example of the b46 but your ecu is commanding much higher boost pressures than other B series engines I've seen
The boost curve is also extremely biased towards the low end. It doesn't look "normal"
If you bought it as a demo (showroom) car it probably doesn't have a tune in it but there's definitely something weird going on.
Its definitely worth investigating but no matter what, just move on back to map 0 and log first. We can work on putting your map 6 together from what we see there.
Default 01-13-2021, 10:29 PM
Got it, ill do a map 0 run in the morning.
Thank you.
Default 01-14-2021, 09:23 AM
New log using map 0 attached. Thank you very much for the help.
Default 01-14-2021, 05:12 PM
Why do you keep stopping at 5500rpm
You have another 1000rpm till redline
Default 01-14-2021, 05:42 PM
Your throttle never fully opens up throughout the entire run
You're boosting above dmebt but I assume that is because you still have your EWG wire on and the jb4 is doing something funky there
I suggest we move onto a really low absolute target just to make sure you're engine is "healthy" and the throttle is capable of opening up before we start to try and ramp things up.
Your engine is also only at the minimum temps for what one would call "warmed up"
Is it absolutely freezing where you are?
Try and wait until your engine oil and water temps are at 90c (195f) or higher before making your pulls
Just drive around a bit longer, you really should refrain from stressing your engine until operating temps are reached, it's extremely bad for the components.
Go to settings /view jb4.... /user adjustment
In the boost column put 12 across the board, 0 for fuel bias and 50 for duty bias
Save it (you should be connected to the car if I recall correctly)
Wait for the car to warm up and run another log starting from about 2200rpm in 3rd gear (keep the pedal at max but without activating the switch at the end that makes it downshift, until the car shifts into 4th on its own)
Do two map 0 runs and two map 6 runs
Be safe, either find a sparsely used road or do highway pulls in early morning /late night
Obviously do it on an straight a road as possible
What we are looking for is 1)your throttle smoothly and fully opening as rpm increases 2)your timing to climb smoothly from the beginning of your run until the end reaching atleast the double digits
It goes without saying use good gas, please let us know what the best gas you have available that you will reliably be able to access.... Even if 100+ octane race gas is available next door, if it is so expensive you will never buy it on your regular fillups, it's not something you want to tune with.
I'm hoping you're throttle problem is because either the engine isn't warmed up or you have an EWG that is acting funny because the dmebt curve drops so sharply. That's why I'm asking for a low boost map 6.
Default 01-14-2021, 06:18 PM
Ok going for a drive and then provide new logs shortly.
Default 01-14-2021, 06:46 PM
New logs attached
