2KLEEN 2KLEEN is offline
Car: 07' N54 Coupe
Default MAP 2 + BEF health check - 05-21-2019, 09:40 AM
Did some pulls on map 2 with small amount of e85 in the tank. Log below.
07' 335i coupe DCI's + PUMP BEF
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-21-2019, 12:09 PM
Borderline timing for map 2 but not terrible. Keep an eye on IAT if you do longer pulls. Also keep an eye on LPFP at high RPM if you add more E85. Otherwise looks OK.
Car: 07' N54 Coupe
Default 05-21-2019, 06:56 PM
Ok thanks! Should I just keep it in map 1 or map 2 is fine?
Default 05-21-2019, 10:09 PM
Daily driving map 2 would be ok.
Just keep an eye on the values stated above
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
