thnguyen89 thnguyen89 is offline
Default Can someone check my log and give me opinions. - 05-20-2019, 05:33 AM
Just changed up some stuff on map6..I'm on full 93oct..anyone want to give me some pointer.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-20-2019, 09:16 AM
Pointer: post in the support section
Default 05-20-2019, 09:36 AM
Lol thanks
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-20-2019, 12:04 PM
Looks like they moved it for you
You should post all your mods so that they can give a better analysis of your logs.
Firmware looks old, may want to update that set all settings back to default and work your way back up but its up to you
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 05-21-2019, 03:44 AM
Hi- any details on your setup / mods?
Default 05-22-2019, 05:09 PM
Jb4+mhd
7" fmic
Relocate inlets
Chargepipes
Exhaust
Custom exhaust
D.p.
Aplina flash
Updating the firmwarr will it give out codes bout the d.p?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-22-2019, 06:24 PM
Are you asking if you update the firmware will the codes for the D.P.'s show up? Yes
07 E90 AT - xHP
FBO
Hybrids
Default 05-22-2019, 06:34 PM
So i have to clear it every couple drive cycles or get the fix?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-22-2019, 06:40 PM
Have your tuner code it out or search how to disable it using tuner pro.
do not use d.p. fix long term
07 E90 AT - xHP
FBO
Hybrids
Default 05-23-2019, 12:18 AM
Fix is not mean to be used 24/7
We also donít alter anything for emissions
Default 05-23-2019, 08:31 PM
New log with new firmware.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-23-2019, 09:03 PM
Need to update your setting also
07 E90 AT - xHP
FBO
Hybrids
Default 05-23-2019, 09:07 PM
Like what?
Default 05-23-2019, 11:15 PM
Like what?
Set your fuel bias to 50
And your duty bias- are you stock turbo or hybrid ?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-23-2019, 11:55 PM
Like what?
Stock Turbo Settings found in POST# 3 of this link
E Series N54 JB4
Hybrid Turbo Settings found in this link
JB4 N54 Hybrid Turbo Setup Directions
07 E90 AT - xHP
FBO
Hybrids
Default 05-24-2019, 05:39 AM
All fuel bias? N duty bias? I'm on stock turbos.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-24-2019, 05:42 AM
Follow ďallĒ settings I posted for stock turbos
07 E90 AT - xHP
FBO
Hybrids
Default 05-24-2019, 06:56 AM
Which is fine- look at your last log. You have values input for both fuel bias and duty bias....which is why i am saying correct them & set to default.
