miksebik miksebik is offline
Default WGDC very high with slight underboost - 05-19-2019, 11:27 PM
can you please help me troubleshoot this?
The WGDC touches 90 when it strives to get to target of 18PSI. Still, I stay a little below. The wastegates were adjusted on my turbos but still, it behaves like this. Maybe some play in the actuators..
Is there a way how to troubleshoot this? Is it possible to have a leak, when the turbos are not that bad when driving.. Thanks
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
Default 05-20-2019, 10:36 PM
Given you have upgraded turbos- Id think 18psi would be a breeze.
Have you performed a boost leak test?
Default 05-21-2019, 12:55 AM
I have to do it..
Before the turbo adjustment, the flap on my front turbo did not close properly so it did not spool very well. Two months ago, my indy adjusted it, but I think he did not do the boost leak test, for some reason he does not like it, even though I have the equipment.
Now it spools much better but after, it struggles. So, OK. We will do the boost leak test and also check the vacuum lines.
Default 05-21-2019, 03:54 AM
I have to do it..
Default 12-08-2019, 02:01 AM
It was cracked aluminium ER chargepipe...
Closed Thread
