Carlos Carlos is offline
Car: '07 335i Convertible
Default 2E1A Ignition, Normal 2Step/NLS code - 05-18-2019, 06:50 AM
Anyone knows what this code means? It popped up along with the following codes:
2E30 Injection valve cylinder 1, input signal
30AC Injection valve cylinder 1, input signal
3E32 Injection valve cylinder 3, input signal
30AE Injection valve cylinder 3, input signal
2E31 Injection valve cylinder 2, input signal
30AD Injection valve cylinder 2, input signal
Iím going to replace all the fuel injectors, but not sure if doing so would correct this code or it means something different.
Default 2E1A Ignition, Normal 2Step/NLS code - 06-05-2019, 05:19 PM
Replaced all 6 injectors, plugs, moved coils around. After erasing codes, they come right back.
Next, will be removing JB4 and erasing codes. Will see what happens then.
Default 07-21-2019, 10:43 AM
2E1A Ignition, Normal 2Step/NLS code - Cleared. Updated my firmware, BEF, enabled antilag+2STEP integration with v14+ firmware set bit3 on the WMI page (mislabeled DTML WMI input) on. Cleared codes and it was gone.
The following codes remain.
Replaced coils, plugs, injectors, but no change. Still working on it.
