halik008 halik008 is offline
Default Log review please: Pre to Post E85 BEF N54 - 05-11-2019, 04:46 PM
Hi guys,
Finally got around flashing my DME with E85 BEF so I did some logs before and after the flash.
It seems post flash my boost is bit less on target than previously. Any advise on what settings to adjust to bring it more on target?
07 335i M/T
JB4 G5 ISO
no kitties
Rennart CBE
ARM Motorsports Stepped FMIC
AL charge pipe
Tial Q BOV
NGK 5992 Plugs @ 0.022
CTS DCI
Fuel it STG1 inline Walbro
Running E57
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-11-2019, 05:10 PM
Seems like FF may need to be raised a bit, and you might need even more duty bias at the top end then you have already. The curve seems to be maxed because it flattens out, might need some other advanced settings to tune it. However, PWM is maxed about 5500 RPM and up on the post-flash log, so there isn't anything left to give. Not sure why you needed so much more WGDC for the same boost level after the flash... Did anything else change?
Default 05-11-2019, 06:01 PM
Nope didn't change a thing
Default 05-13-2019, 12:12 AM
The “post” log- was this the first pull after the flash?
Default 05-13-2019, 04:46 AM
Nah it wasn’t. Did drove it around for 15 mins and did couple full pulls before logging. Does it take bit longer to self adjust after flash than normally?
Default 05-13-2019, 12:41 PM
Imo logs tend to get a bit cleaner after a few WOT pulls and as you drive the car a bit.
Assuming u still have the flash on- how does the car feel?
Default 05-13-2019, 07:14 PM
Car feels great! Can definitely tell the difference all around. Lot smoother power generation even in moderate throttle. Close loop operation is much improved as well as in part throttle where I figure JB4 isn't doing much and letting DME do the heavy lifting
Default 05-13-2019, 11:41 PM
Best of both worlds imo.
We can get a little more aggressive if you wish
Default 05-16-2019, 05:15 PM
That would be good. But let me re-log this weekend and we can go from there
Default 05-16-2019, 10:38 PM
Default 05-18-2019, 07:22 PM
alright. Back with some more logs. Looks bit better at the low end with the boost but looks like at the top I'm still not hitting the target. Or is that normal on stockers?
Default 05-18-2019, 10:48 PM
That’s pretty normal for stockers, especially if running stock inlets
Default 05-19-2019, 08:56 AM
Yah still on stock inlets as well, thought I "reamed" them out a little when I had the engine out.
Would silicone inlets make a huge difference in getting the boost on target at the top end? Just wondering if they are worth the hassle of install
Default 05-19-2019, 08:37 PM
Inlets would help, but the stock turbos can only do “so much” - would it make things more efficient, yes- but you’d still be pushing things pretty hard.
With the low cost of inlets, imo it’s worth it, but install can be a PITA
