Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default JB4 Map 2 and Fuel Wires - 03-06-2019, 04:05 PM
I am looking for some feedback from Stinger 3.3 or G70 3.3 owners that have the JB4 on Map 2 (93 oct) and the Fuel Wires. Nothing else.
That will be my setup in a few days...and was wondering what the HP and Torque numbers end up at. Any performance numbers? 0-60 and/or 1/4 mile.
Stock HP is 365 and Torque is 376...so wondering what the increases are for both. All the graphs, etc are all over the place...LOL.
Thanks in advance for any info !!
pgeneste pgeneste is offline
Car: Kia Stinger 3.3T
Default 03-15-2019, 10:23 AM
Hi Beefer, I'll have lots of that in a few days.
BTW if you have not used (Android App) "Torque Pro (OBD 2 & Car)" it has all the tools to use your cars weight (go to a weight station and get it) and using the accelerometers built into the phone your can get REAL wheel HP maps and stats. Best $5 bucks I ever spent !!!! (Augments the JB4 App with a 2nd phone.)
Phil
Beefer's Avatar
Default 03-15-2019, 11:37 AM
^ unfortunately I have iOS...so I am out of luck. Heard great things about the App though. Need to find someone around me that has a Dragy I can borrow
cilcil88 cilcil88 is offline
Car: 2019 stinger
Default 03-19-2019, 07:12 AM
in for answers as well
Beefer's Avatar
Default 03-21-2019, 01:43 PM
Quick question.
Are Fuel Wires required for any Maps? Or are they optional across the board...giving ~30 whp in the higher RPM range?
Thank you.
Default 03-21-2019, 02:32 PM
Normally you won't be able to run above map2 without them, AFR will go too rich and you'll get misfires.
rboettcher81's Avatar
rboettcher81 rboettcher81 is offline
Car: 2019 Kia Stinger GT
Default 10-24-2019, 06:57 AM
That's good to know.
I just added mine in last night. Still running 93 octane on Map 2. Comparing map2 logs before and after the fuel wires I do see the AFR line being adjusted (albeit small adjustments) on the graph. Before the fuel wires, AFR would literally be a straight line with no deviation during pulls.
I wonder if I could run Map 3 on just 93 octane and not E30. Air temps have dropped considerably into the 40s'-50's. Other mods are BMS intakes and Denso plugs.
Default 10-24-2019, 08:59 AM
Easy to log and evaluate the timing advance to check for knock.
