simonj67 simonj67 is offline
Car: Mk7.5 R Estate
Default Connect kit onto aluminum enclosure - 02-13-2019, 07:50 AM
I'm about to fit my JB4 and connect kit and have also bought the BMS aluminum enclosure.
In the connect kit instructions is says :
Ensure the Connect Kit isnít in direct contact with the metal JB4 enclosure or any other nearby metal
How have people mounted the connect kit my, some form of isolation material or remote from the JB4 enclosure?
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 02-13-2019, 11:37 AM
Im also waiting JB4+BT Kit + Alu enclosure and will be happy to receive this answer... Will Dual side tape be ok? What about bluetooth signal will work if module is inside case?
Default 02-14-2019, 06:35 AM
Make a post here and see what guys are doing: https://www.n54tech.com/forums/showthread.php?t=21742
Dual sided tape should be fine. On putting the module inside the car with Alu I reckon the signal is going to be too weak.
Car: Mk7.5 R Estate
Default 02-14-2019, 11:41 AM
Thank you George, double sided tape it is👍
Default 02-14-2019, 10:39 PM
George Thank you
ZuMBLe ZuMBLe is offline
Car: VW Alltrack
Default 02-19-2019, 07:44 AM
I have the aluminum enclosure and have the BT module electrical taped right against the aluminum. No problems at all. My JB4 and BT is wedged between my factory ECU and battery. My BT module sits on top.
