Default NEW: Infiniti Q50/60 Flex Fuel Kit - 11-13-2018, 09:00 PM
If you are running E85 or ethanol mixes in your Q50 or Q60, you need this kit!
This is a complete plug and play kit to install a Bluetooth ethanol sensor in your Infiniti Q50 or Q60 in about 30 minutes. (Check compatibility for your platform below)
The kit includes the following:
-New 5/16" E85 compatible fuel lines for your engine bay
-Genuine Continental ethanol sensor
-Fuel-It! Bluetooth analyzer (Iphone or Android app must be purchased to use this kit)
-Plug and play harness
*If you are using an Apple product the app can be found by clicking here
If you are using an Andriod product the app can be found here: https://play.google.com/store/apps/d...l_it_eth&hl=en
This kit is compatible with the following:
Q50 2016+
Q60 2017+
LINK for Product:
http://https://www.fuel-it.com/infiniti-q50-and-q60-flex-fuel-kits/
*If you aren't sure whether this kit fits your car, send us a picture of your engine bay to info@fuel-it.com
*Ethanol Sensors don't actually read the ethanol content, the readings are based on the absence of gasoline, so if your fuel is contaminated your ethanol readings may be artificially elevated.
19_Q50RS 19_Q50RS is offline
Car: Q50
Default 01-06-2019, 12:27 PM
I’m new to this but what are the benefits of the flex fuel kit for the Q50?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 01-31-2019, 08:47 AM
FYI your hyperlink is bad due to missing colon marks ( : ) after the s in https
Infiniti Q50 and Q60 Flex Fuel Kits - FUEL-IT!
12.64 @114mph
0-60 4.46
Default 01-31-2019, 09:45 AM
Fixed link for Steve... Working on JB4 Q50 Flex Fuel integration currently for this kit.
Car: Q50
Default 02-15-2019, 07:29 PM
Any new updates on the flex fuel integration for the Q50?
Dekkan53 Dekkan53 is offline
Car: 2017 q50 premium
Default 03-31-2019, 04:08 PM
so only with this kit i can run e85 setup? without fuel pumps?
Car: Infiniti Q50 RS400
Default 04-02-2019, 10:13 PM
Ballpark timeframe for flex+jb4 integration?
jrobohm's Avatar
jrobohm jrobohm is offline
Default 10-24-2019, 03:40 PM
Bump
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8’s
  • AMS HE w/ Aux Tank
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
  • EcuTek Flash (In Work) Seb @ Specialty Z
jrobohm's Avatar
Default 12-17-2019, 07:19 PM
My JB4 w/ WMI is working well with some test code and wiring into the Flex Fuel Sensor. Terry has some polishing to do on the ‘digital filtering’ to smooth out the E85 readings of the sensor feed into the JB4 - via another firmware update down the road - but it is integrated!
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8’s
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
