Stevo585's Avatar
Stevo585 Stevo585 is offline
Car: 2007 335i Coupe MT
Default Anticipated Log Review For Many - DAW Stage 4 - 04-29-2020, 01:50 PM
I know few people in the community have used these turbos, or even seen logs.
PI will be added this weekend, as well as a log.
Going to need some expert help when dialing these in.
I guess we'll see what they can do
2007 e92 335i 6MT -- DAW Stage 4 Turbos -- AD Engineering Port Injection -- VRSF Down Ps -- BMS DCI -- VRSF Inlets -- VRSF Aluminum Outlets -- 7" FMIC -- LSD -- 335is Clutch -- BMS STS -- Stage 2 Bucketless -- n20 Tmap -- Custom 3.5" Single Exit Exhaust
Default 04-30-2020, 07:10 AM
Stevo585's Avatar
Default 05-03-2020, 02:49 PM
The logs are short i know, didn't have the best weather and I need to find a better stretch of road now!
PI seems to be working fine, Fuel is e82.
Plugs are .020 and 1 step colder.
Do you recommend going 2 steps colder and gapping .018 to clean up some of the timing corrections? I may as well look into upgraded coil as well, probably the bimmerlife set.
Do my trims look wonky to you? I have not looked at to many PI logs.
Default 05-03-2020, 03:05 PM
I prefer the 2 step colder @ .018 to .020
Wouldn’t waste the $ on expensive coils (personal opinion)- the Eldor seem to work fine & weve seen many guys go upgraded coils only to come back to stock ones.
Stevo585's Avatar
Default 05-04-2020, 05:09 AM
Perfect, I will start there and see if that cleans up some of the timing.
Besides that does anything stand out to you? I know the logs are short, ill try to get a full one this week.
Default 05-04-2020, 11:40 AM
Get me a bit longer log
Stevo585's Avatar
Default 05-09-2020, 08:43 PM
Here’s map 7
Let me know what you think.
Few questions for you.
What is the common AvgIGN when running full E85?
And do I need to pull back my fuel duty in the RPM ranges that my trims are low?
Thanks again for all your help!
Default 05-10-2020, 08:50 AM
For full e85, ave_ign, lower the better
Which flash are you using right now?
Stevo585's Avatar
Default 05-10-2020, 09:07 AM
I’m using the E85 PI BEF
Just put in n20 plugs gapped to .020 before that log
Default 05-10-2020, 09:08 AM
Iím using the E85 PI BEF
Okay, thatís what it looked like, just wanted to confirm.
Bring that plug gap down to .018
We can bump things up a bit if you want
Stevo585's Avatar
Default 05-10-2020, 09:44 AM
What psi you thinkin
Default 05-11-2020, 09:37 AM
I like to work up incrementally- we could try targeting 20-21 in map 6 & go from there
Stevo585's Avatar
Default 05-11-2020, 09:57 AM
Do I just enter 21 across the board?
Or do I go off the same boost "scaling" as the Hybrid Turbo setup, and keeping 21PSI as the highest boost? if that makes sense..
Default 05-11-2020, 09:58 AM
Whatever you are more comfortable with.
Stevo585's Avatar
Default 05-11-2020, 12:40 PM
What is the main difference?
Default 05-11-2020, 10:22 PM
If it were me Iíd scale, but Iíve died in plenty of setups with a flat curve
Stevo585's Avatar
Default 05-12-2020, 05:07 AM
Died?
I'll have a log up when it stops raining.
Also, should I be looking into upgraded DV's with these boost levels? Or just wait until they leak?
Default 05-13-2020, 06:22 AM
Dialed* not died
Yes to upgraded dv
Stevo585's Avatar
Default 05-22-2020, 04:43 PM
Went with Turbosmart.
I was over boosting on spool up, so I lowered menu 12 and that seemed to work.
Stevo585's Avatar
Default 05-29-2020, 11:19 AM
I'm going to have that 21Psi log up tomorrow, finally the rain is stopping.
Default Yesterday, 06:50 AM
Stevo585's Avatar
Default Yesterday, 05:59 PM
Here ya go!
Compared to one other log I saw with these turbos my wgdc seems kind of high.
Default Yesterday, 07:37 PM
Here ya go!
Definitely can turn it up if you want.
