R3LMV R3LMV is offline
Car: M235I
Default JB4 - Rail Pressure Sensor Fault Codes Help - 09-15-2018, 03:14 AM
Hey,
I had my JB4, BMS intake, Scorpion ********, Forge Intercooler, Forge Chargepipe installed yesterday on my M235.
I've had drivetrain malfunction errors quite a few times and the car is hesitant for a while. I checked connections and everything seems perfect, these were the codes I received:
180001 - ******* ******** detected
102001 - Air mass, plausibility - Tuner code, ignore
119002 - Rail pressure sensor short to ground
101F01 - Throttle valve opening angle pressure - ignore, tuner code
119404 - rail pressure sensor, signal stuck
I've scrolled through a million threads and there doesn't seem to be a clear answer?
Map 2 settings
Boost Safety 20.0
Default Wastegain Position 0
PID Gain 10
Auto Shift Boost Reduction 10
FF/ Wastegate Adaptation 60
Fuel Open Loop 50
The rest below were 0
Tmap Voltage 1.92
Firmware Ver 10/12/15
Interface Ver 4/1/18
VIN ..........
Country UK
Avg lgn 2.4
The rest below 0
Can anyone please help
chunwen chunwen is offline
Car: BMW F10
Default 05-01-2019, 10:42 AM
I will also have this trouble code. Where is the problem?
