maruno88's Avatar
maruno88 maruno88 is offline
Car: BMW 540I B58 G30
Default [solved]Why B58 block at 3.500rpm on Dyno? - 09-02-2018, 03:21 AM
I have DISCOVERED how to unlock debug mode and i have recorded a tutorial to show you. I hope you enjoy and tells horsepower on dyno!
BMW 5 series G30/31 DYNO MODE TUTORIA
You have to do with the engine OFF:
1: PUSH 3 TIMES START BUTTON.
2: HOLD PUSH TRIP BUTTON UNTIL YO ENTER IN THE MENU.
3: PUSH TRIP TO GO DOWN ON THE MENU UNTIL THE OPTION "CHASSIS DYNO".
Hi mates!
Yesterday i went to Dyno to test the JB4 540i B58 BMS Intake, VRSF *****, M Exhaust.
98 octane, Map 3, Sport PLUS, DTC OFF and... pulls to 3.500 and BLOCK there. No increase it to the end.
What I have to do to run on Dyno? Are there Dyno MODE hidden on system?
I am lost on this.
I need help with this.
Thank you!
PD: Images of fail launch.
[Wheelchair] BMW 540i G30 2017 B58 - JB4 - VRSF 4.5" - BMS Intake - M Performance Exhaust.
CADIZ-SPAIN.
madking187 madking187 is offline
Car: BMW 340i 2017
Default 09-02-2018, 03:32 AM
You need EWG cable I believe.
Due to the downp!pe the wastegate can’t control the boost climb specially in map 3 which will add 6 psi.
You probabily hitting 18+ psi now.
Best wishes
m123 m123 is offline
Car: 440i F32
Default 09-02-2018, 03:35 AM
I habe the ewg installed and could not dyno. Also the dynomode did not help.
F32 440i JB4
F11 550i N63tu JB4
maruno88's Avatar
Default 09-02-2018, 03:44 AM
So you cant gave it full horsepower on dyno? It worth it the EWG cable altough not run on dyno?
Thank you.
CADIZ-SPAIN.
maruno88's Avatar
Default 09-02-2018, 04:01 AM
Due to the downp!pe the wastegate canít control the boost climb specially in map 3 which will add 6 psi.
Best wishes
I try to bought but that not assure me to run well on dyno. Do you know about another possibility on this?
Thank you!
CADIZ-SPAIN.
Car: BMW 340i 2017
Default 09-02-2018, 04:45 AM
I did run my car on map3 with 98 octane but when payam check my logs, he advise me to switch to map 2.
Not acting to know but this what he advised me to.
Once my vrsf downp!pe arrives I will try map6 with 16 psi flat. I already have EWG wire.
Take logs and let the BMS check for you.
maruno88's Avatar
Default 09-03-2018, 04:14 AM
Do you think its necesary EWG wire to unlock the car?
One famous tuner said me try to delete codes running in the dyno. Another tells me must be a hidden mode to allow dyno launch. Anyone knows? Thank you madking.
CADIZ-SPAIN.
CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Default 09-10-2018, 05:08 PM
I'm pretty sure on newer BMW you need to activate the roller test option to be able to dyno the car.
Not sure if its the same on a 5 series but on my 2 series you need to have the ignition on (engine off) press the trip meter button and then hold for another about 15 seconds. Normally if I recall it's option 3 and should say Start Roller or something in german like Rollenbetrieb.
Once again not sure how you access the ''secret menu'' on 5 series might be different.
Edit : If it ask for an unlock passcode (which I dont think it does for that) just add up the last 6 digits of your VIN to get the number to unlock.
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BMS Billet Intake // BMS JB4 // BMS Pedal Tuner // BMS OCC // Dinan Axleback + Res Delete // Roof Rack // 365 days of fun
Default 09-11-2018, 09:24 AM
Don't understand the question, sorry!
maruno88's Avatar
Default 09-12-2018, 12:01 PM
CADIZ-SPAIN.
maruno88's Avatar
Default 09-12-2018, 12:03 PM
The car on dyno unlock at 3500 rpm. I needed to unlock and i just found the way and its push 3 times start and hold trip to navigate on the hidden menu. I didnt know that existed. I bring you soon Horsepower with your equipment.
Thanks 4 all!
CADIZ-SPAIN.
maruno88's Avatar
Default 02-20-2019, 05:09 AM
Any solution for this? I dont have found some news to altough get dyno mode on dash, get up to max rpm. How to launch JB4 G30 on dyno?
Thanks.
CADIZ-SPAIN.
