mikeb682 mikeb682 is offline
Car: BMW 335i
Default HELP - 759bhp 1000nm - New Logs - 08-04-2018, 04:52 PM
Please can someone look at these and advice
Runs"ok" in lower powers but on Full power just cuts all boost, fueling etc
Hopefully someone can help
The Charge Pipe did blow off on the second run, not sure if this is related to the ongoing issue
TheDoctor's Avatar
TheDoctor TheDoctor is offline
Car: BMW 335i
Default 08-05-2018, 11:01 PM
I would suggest updating JB4 firmware, then couple logs on map 1 & 2 would be clear to see if the problem resist.
what BEF you have ?
335i M//, 07",IC, CP, BOV, LPFP stage 3, Meth kit, MHD ST,PI,PTE 6466, 32psi ~ 750whp
Default 08-06-2018, 10:18 AM
I don't see to much but follow as he said above. Update the JB4 firmware, can you post a log of map 7 when it's in the higher boost?
I see cyl 4 having a lot of timing drops, check that spark plug/injector/ign coil.
Car: BMW 335i
Default 08-06-2018, 11:58 AM
Thanks, what is the latest firmware update and how can I find it. I thought i already updated it
I will check those also and paid a higher boost one tomorrow
