cbrandt32 cbrandt32 is offline
Default need help with logs jb4 - 08-02-2018, 06:48 PM
I need some help have a jb4 on a 335i that's over boosting map 5 didn't show on log but 3-4 gear also had safety code 3 in last code box. also shows meth value which I'm not using, even water meth signal scaling is set to 60 and I would think that shouldn't show. i tryed to update firmware g5 32-10 and still shows vaule also running e30mix is there a way to get the back flash for e85 for map 5 @pay am @bms terry@bms any insight
g5 iso 32-10- updated firmware map 5 log.csv
g5 iso 32-8 map 5.csv
jb4 hwy driving from buying.csv
Default pic - 08-02-2018, 08:15 PM
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 08-02-2018, 08:52 PM
I dont see over boost really but i do see your HPFP crashing\
'14 435I RWD MHD "Shoup Custom Tune" BigBoost Stage 3 Turbo Spool FX-150 XHP Trans Tune GFB DV+ VRSF Race Cooler VRSF CP BMS Intake Borla ATAK Exhaust Custom Down-pipe Stage 3 LPFP BMP4 EKP M Performance LSD Phoenix Racing PI Intake Manifold AIC2-P controller e85 3.5 TMAP NGK 5992 Plugs "0.020"
Default 08-02-2018, 09:59 PM
the over boost seems to be when I'm driving and I stab the gas like when I did the log it didn't do the over boost you know why its would show meth value and signal scaling of 60 under wmi also was running e30mix
Default 08-02-2018, 10:00 PM
and the pic was taken at idle
Default 08-02-2018, 10:20 PM
wonder if lpfp is a contributor too
Default 08-02-2018, 10:36 PM
Couple things we should do.
Load latest firmware / flash the appropriate BEF.
Link to BEF: http://www.n54tech.com/flash_files/JB4_BEF_061517.zip
Enable 6 cyl timing
Log map 1 or 2- let’s see what is going on.
Default 08-02-2018, 10:40 PM
Enable 6 cyl timing
Log map 1 or 2- lets see what is going on.
what is the latest firmware / appropriate bef I'm new to this thing thank you
Default 08-02-2018, 10:44 PM
Enable 6 cyl timing
in link provided which file would I choose i8a0s or iej0s and which of the files do I pick
Default 08-02-2018, 10:45 PM
Appropriate BEF is based on modifications and fuel being used, I’m assuming in your case you are stock turbo, fuel- if under 30% e85, load the PUMP flash.
Most up to date firmware will be posted as well
Default 08-02-2018, 10:47 PM
Appropriate BEF is based on modifications and fuel being used, Im assuming in your case you are stock turbo, fuel- if under 30% e85, load the PUMP flash.
I have mid cats deleted and stock muffler straight piped had turbo replaced under warranty
Default 08-02-2018, 11:11 PM
Enable 6 cyl timing
do they need to be hex files? they didn't wanna load I'm using jb4 inter face maybe its older? or do I need mhd bimmer boost thank you
Default 08-04-2018, 02:11 PM
up dated to 32 12 12 updated firmware lowered wastgate adaption to 60 made open loop fuel 75 from 69 reset adaptions 1-7 and meth trigger on 3 since i still see meth value showing i ordered a cable for mhd n the otg cable to try out other route seems like afrs are lean in lower boost range but would say doesnt over boost wastegate adpation went to 105 thank you
updated to new firmware.csv
lpfp drop e 30 mix low fuel.csv
this above log looks like lpfp is cause of low fuel
Default 08-05-2018, 10:35 PM
Attachment 77817
Attachment 77825
Attachment 77819
The log above is too short to evaluate
