mikeb682 mikeb682 is offline
Car: BMW 335i
Default HELP - 759bhp 1000nm - Broken - 08-02-2018, 12:42 PM
Hi All,
New to this, brought the car only 2 weeks ago and now having issues
Running 759bhp and over 1000nm on Map 6
At present Map 6 is now slowest Map, trys to come onto boost and then on full throttle just dies, struggles to spool up and then just as it does cuts everything
The lower maps work much better to rev through and are far quicker
Its running 2 x Varagos 2+ Turbos, fully forged engine and all the mods needed to go with
Codes for Fuel mixture and post *** are coming up but not sure its related?
Have attached the logs for Payam, Terry and Steve to look at after speaking with Ando
Any help would be amazing
Default 08-02-2018, 01:04 PM
Can't tell too much from these logs. They're too short to see exactly what's going on
First, update your Jb4 firmware.
Get a log in 3rd gear from 2k till redline with pedal all the way down. Map 1.
Car: BMW 335i
Default 08-02-2018, 01:14 PM
Brill thanks ill go do it Now
Car: BMW 335i
Default New Logs - 08-02-2018, 02:11 PM
Firmware has now been Updated
So...
Log one is done as requested
Log two as requested.....Until a large pop....I believe the Pipe onto the throttle body may have blown off, not sure very dark out
First Run went fine
Thanks in advance
T_H_O_M_A_S T_H_O_M_A_S is offline
Car: M135ix
Default 08-02-2018, 02:28 PM
what engine makes 800 bhp with only 15 psi boost on average ?
M135i PWG , FBO , PS2 , LPFP st2 , HDP6 custom for N55 , wedge MHD mapping , XHP AT8
Car: BMW 335i
Default 08-04-2018, 02:35 PM
Any help on the new logs would be amazing
Default 08-06-2018, 03:36 PM
I feel like I've seen an answered this before.
Update firmware, cyl 4 seems to have major issues with timing. I'd look into that.
