inevitab1e's Avatar
Car: 2013 N55 135is
Default First log - E85 BEF/Map5 - 07-31-2018, 12:53 PM
First log check with the E85 BEF / JB4 Map5. Running around e35-e40.
Thanks! (2nd image has some IGN activity I've seen recently, know what causes that?)
2013 E82 135is N55 JB4-BEF FBO
Default 07-31-2018, 11:08 PM
Boost could use a bit of refinement
And some timing issues on a few cylinders
Overall not awful for a first log.
Higher AveIgn is a built in safety feature- higher Ave Ign = lower boost target
inevitab1e's Avatar
Car: 2013 N55 135is
Default 08-01-2018, 10:11 AM
Ya, the avg.ign was reset for this new BEF. Went from 4.7 --> 3.1 during the run.
In the second image, are those the timing issues you're talking about? In the middle of the log? Know what causes that strange behavior (higher/lower mirror?)
EDIT: 2nd test WOT redline. Same IGN activity of the higher/lower readings in the middle of the log. Are there any specific default JB4 settings to change for the BEF usage? FOL, FF, DWP
Default 08-01-2018, 04:33 PM
Raise duty bias to 65 from 4.5k rpm and up and get another log that should have you closer to target.
inevitab1e's Avatar
Car: 2013 N55 135is
Default 08-03-2018, 12:04 PM
Duty biased adjusted. DSC completely off, Think I had the AC on. Feel strong, little hesitation.
Default 08-05-2018, 11:11 PM
Looks pretty clean!
Wgdc is maxed, so not much more DB tuning will do.
Glad the car feels strong, if you want to hold boost better to redline- time for a Pure turbo upgrade
inevitab1e's Avatar
Car: 2013 N55 135is
Default 08-06-2018, 07:22 AM
Looks pretty clean!
Last question.
Do you recommend setting FOL, DWP, Menu 10,11,12 to any specific values for the BEF?
EDIT: Know what causes this IGN activity?
