dushash dushash is offline
Car: 2007 328xi e90 a/t
Default Guidance needed: I want to get 600whp on n63tu with jb4+bcm+meth+3.5 bar tmap - 05-28-2018, 09:20 AM
Basically I want to get what Terry did on n63tu - got about 600whp http://www.n54tech.com/forums/showpo...1&postcount=64. Right now I have (2014 x5 n63tu) Stage 1 flash from BPC - which is just under 500whp (dynojet) on 93 fuel and runs like clock - very happy, except I want max power now. I'm not planning upgrading turbos, so I want to get maximum out of stock turbos (apparently they can go up to 25psi) + meth.
As I understand, if I go with n63tu_Beta jb4 (with updated firmware) + bcm (s63tu) + TMAP 3.5 bar (N20?) + meth = I may just get 600whp give or take (at least this is what Terry got on similar setup).
I'm ok with disconnecting MAF and getting constant CEL. I know that I'll need to run extra fuel pressure wires to each fuel rail (probably 2 large connectors given that my car is 2014). I also know that I'll need to attach BCM to boost solenoids under passenger side IC. I will also get 2Gal. stealth F10 tank and meth kit (with FSB) too with CM7 double nozzles.
So I have following questions:
1. I would appreciate if you guys can confirm or correct me if I am missing something? I want to order this setup soon if there is nothing missing.
2. Am I correct that this setup will run on map 8 - progressive meth map?
3. Given this setup - what is the best place to mount dual CM7 nozzles: chargepipes or IC outlets?
4. What fuel will be best to use in this scenario given this setup?
5. Are dual CM10 nozzles overkill?
I very much appreciate your help.
Thank you,
Dush
Default 05-30-2018, 04:34 AM
Guys I only posted here, because BMS website suggested to post here for any answers and support technical info.
All I need to know is basically - if my shopping cart at BMS (the list of setup parts i wrote) has everything needed and I'm, not missing anything. Help me help you (BMS) make money on me. It's not like I'm asking advise on how to build a track Subaru with competitor parts. I'm asking advise on what parts to buy from BMS to achieve my goal.
If this thread is not appropriate - please direct me to where I can ask this kind of questions. Maybe I can email BMS support - will this work better? Please advise.
Thank you
Default 05-30-2018, 10:07 AM
@Payam@BMS- he can get you squared away / confirm :P
Default 05-30-2018, 10:14 AM
Thank you very much!
Default 05-30-2018, 10:19 AM
Thank you
Email me directly and I can reply to you much faster and help you out directly for what you need.
Payam@burgertuning.com
Default 05-30-2018, 10:21 AM
Thank you!
HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default 03-11-2019, 05:42 PM
Hi, did you ever get this going?
