grh372 grh372 is offline
Car: 2014 mini cooper s
Default fault codes and limp mode - 05-06-2018, 05:35 PM
I have used the jb4 for almost a year and love it. last week right after starting the car the "drivetrain malfunction, maximum drivetrain output not available" message would appear. i turned off the car and restarted and it was normal.
week later same message now with the check engine light, scanned and found codes
121201 boost pressure sensor, plausibility, caster: pressure too high.
121532 boost pressure ambient pressure comparison boost pressure too high
120408 boost pressure control: shutdown due to reaction
anything i should be looking for? i took the unit out and haven't had an issues since, I'm really missing the power of the jb4 though
Cioolio Cioolio is offline
Car: MINI F56 JCW
Default 06-08-2018, 07:43 AM
I have the same problem with the same errors. Anyone know the problem?
Default 06-12-2018, 11:01 AM
When does it happen? After a pull?
akgambino akgambino is offline
Car: 2013 F30 335i xDrive
Default 05-20-2019, 07:53 PM
Did anyone ever find out the cause for code 121201 boost sensor plausibility?
