Sutton54 Sutton54 is offline
Car: 2007 bmw 335i
Default Single turbo 30ff - 04-02-2018, 07:27 PM
When you get this code and go into limp mode is it meaning a boost leak?
Ripper61 Ripper61 is offline
Car: 2010 535i M-sport
Default 04-03-2018, 09:12 AM
Some good information here:
http://www.n54tech.com/forums/showthread.php?t=43181
30FF:
30FF Exhaust fume turbocharger low side
EXPLANATION: ECU boost under ECU target
FIX: Often caused by boost leaks, leaky DVs, broken vacuum lines, etc. Also possibly tuning related. If using a TMAP tune (SSTT/JB+) it may be a sign you need to reduce your boost level, or perform the solenoid bypass.
2010 535i M-sport, BMS DCI & OCC, RB inlets & PCV, RB Ones, VRSF ****, ER FMIC & CP, MHD Stg 2+ 93, OE M6 167's
Default 04-03-2018, 09:16 AM
It's disabled in the BEF.
Bimmer55 Bimmer55 is offline
Car: 2009 335xi
Default 02-25-2019, 07:06 PM
Terry I am getting 30ff on single turbo too with jb4 is that normal ? It is shadow code .no check engine light
