(#1701)
Default 02-17-2019, 10:26 AM
Let's look at the tuning again when it heats up for sure!
Carsonigel Carsonigel is offline
Car: 2018 stinger GT
Default 02-17-2019, 10:34 AM
Hey terry I had started a thread on the stinger forum about some weird limp on my stinger at exactly 94mph on map 3 or high, had it happen on a run on map2, did it first pull, not second. Attached a log of map 3 as well. Let me know. 18 rwd, cai, 30-35 percent e85 in tank and plugs at .22.
Default 02-17-2019, 10:48 AM
Yes I see the problem, fuel pressure tanking!
Less boost and/or less E85.
Default 02-17-2019, 11:05 AM
Okay I will try putting more pump gas in to see if that helps, if not, does that mean I have to pretty much lower boost up top on any map above 3?
G80SPORT G80SPORT is offline
Car: 2019 g80 sport
Default 02-17-2019, 12:02 PM
Can you tell a layman like me what exactly we could keep an eye out for on logs and graphs, i want to be able to verify myself that everything is safe.
Default 02-17-2019, 12:14 PM
Not easily, no. But this thread has some basics. While not all of it applies to the Stinger most does.
Logging Parameters and their Meaning - N54Tech.com - International Turbo Racing Discussion
Default 02-17-2019, 12:15 PM
Less boost and/or less E85 to keep fuel pressure from dropping below 8 (1200psi).
Kelson Kelson is offline
Car: Kia stinger gt2
Default WMI - 02-18-2019, 02:02 AM
Are we able to raise the boost higher than the 0-75 if we are using 100% methanol instead of the 50/50, to add additional fuel? I would love to be at +10 or 11psi 😁 I've been running 70% meth for over 3 months now and at 75 on the wmi map. It just kinda feels blah now and I'm ready for more. My 2004 hyundai sonata 2.4l is making more hp than my stinger is. 😓 but seriously it is. And I'm very familiar with tuning for afr and knock from my experience with high boost 4 cylinder motors. The stinger is begging for more boost!
Default 02-18-2019, 08:57 AM
I'd have to see the JB4 log for any tuning advice, but the stock turbos stop making power around 18-19psi. So that is as high as you'd want to run it in my opinion.
Default 02-18-2019, 09:00 AM
Took a few runs last night in the chilly 45f temps we have around here lately.
Mods: JB4, BMS Intake, BMS Prototype Intercooler, 93 octane, stock rims/tires, stock exhaust system, no WMI, full weight, etc. JB4 set to spoof intake air temp up around 30 degrees.
I'm really pleased with the trap! Had boost set to -4psi in 1st which helped off the line but with 1WD on stock tires traction is always the enemy.
Default 02-18-2019, 11:23 AM
Think the suspension bits helped at all on the runs
Default 02-18-2019, 12:26 PM
Yes no doubt a benefit. But mum is the word on that until they are ready to ship.
ddebart2 ddebart2 is offline
Car: Kia Stinger
Default 02-18-2019, 03:13 PM
Apologize if this is a dumb question but I'm pretty new to this. Was doing some logs during the drive home today, and my Ign 1 numbers look way off compared to others I've seen in this forum. They get pretty high and look like they bounce around a lot more. Logs are attached. Is this normal behavior? Car is stock except for Stillen intakes and using pump 93. Edit: and Densos gapped to .024”
Thanks,
Dan
Snared Snared is offline
Car: 2018 Kia Stinger
Default 02-18-2019, 03:43 PM
These look normal, if the no boost issue comes back we can look in to it further.
Hey Terry
I had the no boost situation happened again. I attached the logs
Default 02-18-2019, 04:04 PM
Originally Posted by Snared
Hey Terry
We'd want to see a log of what was going on before you went in to low boost mode, if you leave the JB4 connected so it can auto-log runs and appends them to the same file (under the app settings) makes it easier to track down.
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 02-19-2019, 05:53 AM
Thanks,
Dan
Dipping down during shifts is not a problem at all. If you start seeing ign1 gradually decrease (like going down a set of stairs) as your RPMs are climbing then you should be concerned.
Default 02-19-2019, 10:31 AM
JB4 Mobile support requests go here: JB4 Mobile - N54Tech.com - International Turbo Racing Discussion
Default 02-19-2019, 11:21 AM
Hi Terry
I enabled that logging function. I was thinking of downgrading from v8 to v7 firmware to see if I have the same issue. Will I lose any settings or will I have any issues completing this since there are enhanced functionality in the newer version . I am guessing that it should be ok but I thought I would ask .
Default 02-19-2019, 12:21 PM
No you can move between v7 and v8 without issue, but won't make a difference. Whatever problem you have you probably have on any firmware version.
Default 02-19-2019, 12:27 PM
I only started to get this issue when I went from v5 to v8. Only upgrades I have done in the last couple of weeks was BMS Intake and AP intercooler. I had no boost issues on v5 with these mods. Other mods are ***/catback exhaust/spark plugs. I do have fuel wires installed. Anything I could check ?
Default 02-19-2019, 12:28 PM
For some reason it blocked the short form of ********* from my last post lol
Default 02-19-2019, 01:12 PM
Exhaust mods can cause the car to "over boost" a few PSI over target at low throttle and trigger a false alarm low boost mode in some rare cases. Capture the issue coming up in a log and I can setup a JB4 setting to accomidate.
Default 02-19-2019, 04:54 PM
Should be OK on map3 with an E30 mix. Post a log if you want me to check it out though!
5m4770n 5m4770n is offline
Car: Stinger
Default 02-19-2019, 05:13 PM
Can the jb4 be used to create burbles like the new Audi TT rs?
Default 02-19-2019, 05:32 PM
No we can't change the injection timing with it, so you'd need a back end flash map to add that in if you wanted.
