PawlyGuNNz PawlyGuNNz is offline
Car: 135i N54 6sp MT
Default Fault code 29F1... fuel pressure plausibility - 02-11-2018, 11:16 AM
Anybody have experience with findings or fixes for this code?!
jb4 g5 ISO,MHD\JB4 BEF, Pure stage 2 hybrid hi flow n54,PR stage 3 fuel pumps, ADE port injection,RB PCV, BMS occ, ER CP, TIAL BOV, VRSF Hotside inlets, VRSF 7" fmic, VRSF 3" ***, n55 mid, Berk Race, NGK GTR plugs, HPF Spec smfw twin disc clutch
Default 02-11-2018, 05:27 PM
Might be one you ignore. I'd have to see a log of it coming up, though.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 05-17-2018, 07:21 AM
Did u resolve this? I got this today too it popped up and then disappeared. Although I was on negative trims due to incorrect fuel bias settings from 3000 to 5500 rpm.
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018Ē gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020Ē, stock everything else, 374.9 rwkw Mainline Dyno Aus
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 08-12-2018, 03:59 AM
Is there any new information on this. Iíve had this code ever since my tune. Itís been happening everyday now within the first few minutes of driving. Once cleared itís usually gone through the remainder of the drive.
Car runs fine, just annoying.
Default 08-12-2018, 08:34 PM
For the people that throw this code, reasons can be different, itís really case by case.
Bigs135's Avatar
Bigs135 Bigs135 is offline
Default 29f1 code - first start up - 01-06-2019, 01:12 AM
I am getting a 29f1 code. It is also my first start up with my ST. My car will run for 30 seconds and then shut off with the cooling fan speed high and running.
During the build we replaced LPFP with a Stage 3 from Fuel-IT. Thought that I should mention this since it is a fuel pressure problem.
Any help with this code would be greatly appreciated!
PrincessleahN54 PrincessleahN54 is offline
Car: 2011 335i
Default 05-13-2019, 09:20 AM
Bigs135, Did you get this problem fixed? If so, what/how? Im having the same issue.
135BMWAddict's Avatar
135BMWAddict 135BMWAddict is offline
Car: 2009 135i
Default 05-19-2019, 10:47 PM
Did either of you figure out what this was? Having the same issue after a ST install on first start up.
Mods
- ST GTX3582R, JB4+BEF, PI, Stage 3 Fuel, E80
imgland imgland is offline
Glando7
Car: e90
Default 11-20-2019, 06:15 PM
I've had the same issue happen numerous times when I start the car. From a cold start it will essentially go into limp mode, idle changes, fans kick on, and the engine with the slash comes on. I've turned the car off and restarted it with no issues. Very intermittent! I've got a Stage 2 Bucketless LPFP installed but these symptoms began well over a year after the install of the LPFP.
Unfortunately since this happens at start up and its intermittence I have no logs to back this.
Has anyone have any theories on this?
