(#326)
52172 52172 is offline
Car: 2015 335i
Default 03-18-2019, 09:35 PM
The cast turbofold looks sick.
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 04-16-2019, 03:06 PM
Originally Posted by luchocamp
few updates here :
HPFP oem works fine but not allow too much Ethanol. Max I see now is E25
Buy new Fuel It 525 walbro did not see any difference at all vs 450 walbro or stock LPFP pump.
Car is running great E25 127mph or 100octane unleaded fuel 127mph
11.1 - 11.3 sec 1/4 mile
in a few weeks I will try VP MS109 and more boost ....
What was your max ethanol mixture that you ran before the 8374 install? I've been running e50 all of the time with the stage 2 LPFP and stock HPFP and my stock turbo. I'm planning to do as you are with a second LPFP pump for stage 3 and PI when I install my 8374 this summer. I'm hoping I can still run with a high ethanol mixture afterwards.
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 v3 - Map 7/e50/Custom tuned exhaust/stock turbo/Resonator Delete/MHD & JB4 e85 BEF/Stage 2 LPFP Walbro 450
Summer '20 install: Speedtech BW 8374/PI & Tune by Trebila
luchocamp's Avatar
Default 04-16-2019, 07:26 PM
Every car is different. I will suggest that you start with E25 and make some test, then increase E30, etc.
A90 Supra Full Weight No Nitrous 10.78@133mph
BMW M4 stay tuned
Drag Track online set up on instagram @luchocampusano YouTube Lucho Campusano
Default 04-17-2019, 07:45 AM
yeah for sure, I was just curious.
luchocamp's Avatar
Default 04-24-2019, 08:12 AM
22psi log efr8374
BMW M4 stay tuned
luchocamp's Avatar
Default 05-21-2019, 02:33 AM
BMW code 11AC02
Last week hpfp N55 oem fail.
Time to try B58 hpfp for myself and give reports to the community.
BMW M4 stay tuned
luchocamp's Avatar
Default 05-21-2019, 10:55 AM
BMW M4 stay tuned
Stoolz Stoolz is offline
Car: 11 135i
Default 05-22-2019, 02:13 AM
My Vargas DBB traps 126, I would have thought S3 would be a lot higher? Not throwing shade, I'm actually going to do a S3 setup.
luchocamp's Avatar
Default 05-22-2019, 02:40 AM
Great for your set up. I noticed 135i e series dct should be around 400lbs less than f30 335xi ...
That make a huge difference on trap speed.
BMW M4 stay tuned
Car: 11 135i
Default 05-22-2019, 03:20 AM
Oh yeah that makes sense, How's the drive? Not too laggy? Maybe x drive would cut trap a little too.
luchocamp's Avatar
Default 05-22-2019, 06:09 AM
speedtech stg3 using efr8374 is a twin ball bearing unit it is less laggy than stg 2 or stg 1 for sure.
BMW M4 stay tuned
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 05-22-2019, 09:11 AM
Yeah there's no way that 8374 is less laggy than a PS1
E90 N55 RWD 6MT MHD
luchocamp's Avatar
Default 05-22-2019, 02:53 PM
Funny, I had test oem, stg1, stg2 , and stg3.
Best 0 -60 feet is with speedtech efr 8374 because is ball bearing with a good manifold.
BMW M4 stay tuned
Default 05-23-2019, 04:35 AM
You're awd, brake boosting on the line, and making a ton more power than a PS1 so of course it's faster to the 60ft mark.
I'm talking about lag.
E90 N55 RWD 6MT MHD
luchocamp's Avatar
Default 05-23-2019, 11:41 AM
Sometimes you think you know something but then realized you were wrong.
No laggy because is a better turbo twin ball bearing using your 6 cyl engine. Look the pictures at beginning using oem,stg1 and stg2 has more lag because your are pushing with 4.5 cyl and journal bearing.
Keep it up
BMW M4 stay tuned
Default 05-23-2019, 12:10 PM
I'll PM you
E90 N55 RWD 6MT MHD
luchocamp's Avatar
Default 05-26-2019, 04:31 PM
hi guys, some update ... we made several adjustments to hardware ( exact manual location of wg ), change a defective port injection hose, install B58 HPFP, and also XHP stg 3 software.
In the past my best e.t. was 11.01@127.4 running a non lineal boost 24 down to 21psi using E40 blend.
Today and after one week with the car I upload on Dragy a clear pass of 11.05@126mph runing 21psi of boost using 100 octane fuel.
I am running my 19 inch wheels with firhawk indy 500 and manage to make 1.69 on 60 foot.
I will upload jb4 log graphic soon
BMW M4 stay tuned
luchocamp's Avatar
Default 05-26-2019, 04:55 PM
DA 1,831 feet
BMW M4 stay tuned
luchocamp's Avatar
Default 05-26-2019, 05:13 PM
BMW M4 stay tuned
N54-SHI N54-SHI is offline
Default 05-27-2019, 10:28 AM
Hi luchoucamp
which JB4 Firmware are you useing?
luchocamp's Avatar
Default 05-27-2019, 11:53 AM
Last one. N55 F PWG INT 13 T1
BMW M4 stay tuned
Default 05-28-2019, 08:05 AM
13 T3 should be more faster for launch, you can test it.
Default 05-28-2019, 08:06 AM
if you need it I can email you.
luchocamp's Avatar
Default 05-28-2019, 08:18 AM
uff many thanks !
What is change on T3 to improve launch ?
What are your 60ft and turbo ?
BMW M4 stay tuned
Default 05-28-2019, 10:06 AM
uff many thanks !
2013 335ix stage1 turbo
0-60mph 3.5
I had not test the 1/4 or 1/8.the 0-60mph(we test 0-100km/h) is enough to test the launch power.
T3 can up the launch boost and torque .what is you email? I send it to you .I think you will be the second 10.X F30 335ix
