paulkane paulkane is offline
Car: 2010 N54 135i E82
Default Terry: N54 Advice needed Code 2D2E - 07-13-2017, 01:23 AM
2009 E82 135i N54
I'm no tuner - so please be patient with me.
Mods done: -
  • down-pip-es done (keeps rejecting that word?)
  • BMC Air Filter in OEM intake
  • Boostpipe with Tial Blowoff valve - plumbed back into front turbo air intake.
  • Latest JB4 with bluetooth adapter and app from BMS
General Notes: -
  • has 6 brand new series 12 injectors installed and coded
  • Brand new Plugs and Coils
  • Brand New Battery
  • ECU is a stock standard OEM flash (no back-end flash)
Whats been happening (under map 0): -
  • throttle / boost was very jumpy especially around midrange (3000 rpm)
  • Under smooth / mild acceleration it was like all of a sudden you would get a surge of acceleration as if you had pressed your foot down suddenly (this seems to happen around 2500-3000 rpm
  • Cruising in top gear using Cruise Control at around 120kph (75-80mph) - when you hit an uphill the intervention of the cruise control is jumpy with jerky throttle/boost.
  • Car (intermittently) shows the code 2D2E at that midrange and has shown that code at cold start once.
  • Everything feels ok at full throttle?
I need some help to problem solve this issue and any advice would be appreciated. I suspected that maybe someone previously might have fiddled with the ECU coding and I had it flashed back to stock to be sure it wasn't an underlying ECU coding issue.
If you want me to upload a log - please if you could give me some advice in that regard.
Default 07-13-2017, 02:20 PM
2D2E is just a tuner plausibility fault, from having menu10 and/or menu12 cranked a little too high, which causes extra boost in front of the partially closed throttle, improving response, but can trigger that shadow fault.
You may need to lower those menus. I'd start by lowering menu10 to 2000rpm.
Default 07-14-2017, 12:10 AM
Thanks. From reading your reply and the JB4 Menu summary - it certainly points to Menu 12 - the description of "oscillation and strange behaviour" is a good description of what I am experiencing with the car under low throttle.
My Menu 10 was set to 3000 - i took it down to 2000.
My Menu 12 was set to 2700.
Ok - so a couple of questions:-
  • Are these menu's influencing the wastegates for all menu's including Menu 0?
  • Menu 10 range (0-5000rpm) - can you tell me what the operation is? i.e. what is happening with the wastegates if set to zero rpm vs 5000rpm. or what is different between the 3000 setting and the 2000 setting?
  • Menu 12 range - suggested is 2400-2800 - which is quite a narrow range. If I am experiencing oscillation under low throttle at 2700 setting - do i work up or down and whats the difference?
Default 07-14-2017, 12:57 AM
One last question - the 2D2E code - described as "Angle of Throttle valve - intake pipe underpressure, correlation". The word "underpressure" implies that the code relates to the intake pressure being below the expected pressure relative to the throttle position.
Q: Does this code throw when the intake pressure is BOTH above or below its expected pressure level for a given throttle position?
Q: Would this code also throw if you had a boost leak?
pepper135i pepper135i is offline
Car: 135
Default 07-14-2017, 03:37 AM
I also had the same issue , hoping to get some more info . I backed menu 12 down a bit but same issue . I'll adjust menu 10 and give it a shot
jk308 jk308 is offline
Car: 2008 335xi e92
Default 02-21-2018, 11:00 AM
I am having the exact same issues at the same engine speeds. I have backed menus 10 and 12 down to 2000 with no resolution. I'll play with these menus a bit more and see if it makes a difference.
z4s4 z4s4 is offline
Car: 2011 Z4 35is
Default 04-21-2018, 07:56 AM
Having the same problems listed above on JB4 or stock, has anyone found a solution or other checks to try?
Tried the JB4 adjustments above but no luck. Resetting the ECU fixes but slowly returns. Was able to still get it smogged in this condition. Replaced many parts/sensors, getting expensive
Paddy Paddy is offline
Car: E91 335i
Default 07-01-2018, 01:36 PM
Sorry for the thread revival here, like the op I'm totally new to tuning, and am also getting the 2D2E code. My question is, how or where do I find the menu 10 and menu 12 to make the adjustments?
Haynpunch's Avatar
Car: 07 E90 335i
Default 07-01-2018, 02:21 PM
http://www.n54tech.com/forums/showthread.php?t=10605
Wheel Control Guide in Post #3
https://www.youtube.com/watch?v=HDjD4OcDIGU
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 07-01-2018, 09:17 PM
Originally Posted by Haynpunch
Thank you for the assistance
mr68gts mr68gts is offline
Car: 09 335i
Default 12-22-2018, 10:31 AM
Was this resolved by playing with menu 10 and 12 at all? I just installed a brand new jb4 last week and the same 2d2e code popped up on the way to Vegas from Phoenix. Part throttle on cruise at 65 was jerky as described above. (Holiday weekend so speed limit was word of the day) Turn cruise off and it's fine.
I'm going to play with 10 and 12 menus and see if that solves it.
I did clear the code and it didn't come back.
Paul
Chunky Osiris's Avatar
Chunky Osiris Chunky Osiris is offline
1Lover
Car: 2008 135i MSport PPK - FBO - MHD Tune
Send a message via Skype™ to Chunky Osiris
Default 05-14-2019, 06:04 AM
When adjusting these settings on menus 10 and 12, do the changes take affect immediately or do I need to exit that menu or restart the car or something?
james008 james008 is offline
Car: 09 335i M-Sport
Default 05-15-2019, 07:34 PM
Having throttle position problems. Jumps from about 9% up to 12% AFRs jump and Boost fluctuates while Accelerator pedal stays constant. Running MHD but does it flashed back to stock too. Only showed up in the last 2 weeks and gradually getting worse. Been running MHD for 2 years.
Cleaned throttle body and all sensors. Only code is 2D2E. Frustrating as the car has been running great besides this hiccup.
Resetting adaptations doesn't do anything, sometimes it's worse than others. Starting off in 1st from a standstill will provoke it. Cruising at any speed while throttle is around 9% might cause it other times it doesn't.
I have no experience tweaking tables just run MHD's maps.
Littlet_23 Littlet_23 is offline
Car: E92 BMW 335I 2006
Default 06-10-2019, 09:35 AM
Did anyone solve this problem. How do you get did of code 2d2e?
jokers_greg jokers_greg is offline
Car: 2007 E90 335i
Default 07-23-2019, 01:02 PM
little thread revival, feeling these symptoms some times and getting the code on occasion
fazman fazman is offline
Car: e90 FBO
Default 01-13-2020, 12:39 AM
Just like the OP I am having the same issues. I also had a lot of work done recently and then started messing with Menu 10/11/12 because of other codes. I wish someone would post an update with either a solution OR the things they attempted with no success. Both pieces of information will help so the community so we don’t have to redo the same troubleshooting.
FWIW I did get BMS inlets in the stock location installed just before getting these codes. Terry, any other advice rather that trying combinations of Menu 10/11/12
I’m also getting 29F4 / 29F5 even with four new O2’s installed. My original stock O2’s lasted until 186,000 without any hiccup using the D-P Fix continuously since 45k miles on the clock (long term testing). I have since dialed it in stronger to 4 OClock and still get the codes 29F4 / 29F5
I am also struggling with 2DED.
For about 2 days I was getting the thermostat code 2EF4 (I also had my waterpump and thermostat replaced proactively recently (I got all the parts from FCPEuro).
I am getting all these codes no matter which Map I use on the JB4 (0/1/2/5)
Car: e90 FBO
Default 01-15-2020, 01:30 PM
So I played around with Menu 11 (mine was at 4000 RPM), I dropped it down to 0 RPM and the 2D2E hasn’t come back... but the car feels kinda sluggish so I moved it up to 1000 —> 2000 —> 3000 but then my cruise control was getting that same stumble so I move it back down to 2000 rpm. I haven’t gotten that 2D2E after that. I am still struggling with the 29F4 / 29F5 and now at WOT I am getting a cyl 4 misfire with SES so I ordered new coils because spark plugs are already new (Should arrive Monday). The 2EF4 has not come back but I do notice my oil temps around the 200-210 temp range (Generally I have noticed the car should be around the 220-240 range).
My menu 12 is at 2500 rpm.
