Jaydee11 Jaydee11 is offline
Default 2ABD code - 12-21-2016, 02:43 PM
Cannot seem to figure out this code
2ABD intake pressure sensor rerunning
Replaced map sensor on the intake but code still returns
Mods: jb4 dci *** less dp vrsf chargepipe tial bov
2007 335i 100k miles
Any ideas?
Default 12-21-2016, 02:49 PM
Photo of user adjustment page?
Default 12-22-2016, 01:07 AM
Default 12-22-2016, 03:18 PM
Photo need to be under 200K
Default 12-23-2016, 12:29 AM
Default 12-23-2016, 09:57 PM
Change all duty bias to 0, TMAP to 0, 6cyl timing to 0, 3rd gear boost to 0, clear all faults, and do a JB4 log.
Default 12-26-2016, 03:56 PM
okay updated those settings and took a log.
Default 12-27-2016, 07:55 AM
Try a log on map 1 and set your 6-cyl timing value to 5. Map 2 looks like it may be a little too aggressive for your fuel.
Default 12-29-2016, 07:30 PM
okay cleared codes set it to map 1 and updated settings and took a couple logs.
half engine light still appears along with the code 2ABD intake pressure sensor, re-running upon 1st restart of the car
Default 12-29-2016, 07:57 PM
Photo of DME area? Any other wiring in there other than a JB4?
Default 12-29-2016, 08:02 PM
No other wiring beside JB4 Haven't opened or touched any wires in the dme box since using a dp fix about 10,000 miles ago.
Default 12-29-2016, 08:05 PM
2ABD is normally something TMAP sensor related. Most often another tuner installed if the car was bought used. If you remove the JB4 does the fault still appear?
Default 12-29-2016, 08:17 PM
I installed JB4 about 35,000 miles ago and never had an issue before. I checked tmap connection and sensor and it looked good but when I pulled the map sensor on the manifold it had some oil on it and look fried so I replaced the manifold map sensor with a new oem one. Haven't messed with removing the jb4 yet.
Default 12-30-2016, 09:20 AM
2abd can also be caused by a boost leak.
Default 12-30-2016, 10:35 AM
Ya but do the logs show any signs of a boost leak?
Default 12-30-2016, 04:51 PM
It can be but normally in my experience it's a TMAP sensor voltage error. Caused by sensor calibration settings in the BEF or JB4, faulty sensor, or other wiring in the DME box interfering with the sensor signal.
Immoralus's Avatar
Immoralus Immoralus is offline
Car: 2008 335xi
Default 12-30-2016, 10:49 PM
2abd is a super annoying code... I had the same issue and my car wasn't working properly. I swapped out a 4bar with a harness and the car has been fine since... for the most part.
08 335xi- JB4/Trebila,RB Inlets, VRSF CP ,FMIC, DP ,BMS DCI,e50 and Fuel-it Stage 2. 11.8 @ 118
Default 01-02-2017, 06:06 PM
Yeah, just adding to the list of potential causes.
We got that error when our CP inexplicably regurgitated the o-ring.
Default 01-17-2017, 11:11 PM
Decided to just go ahead and replace the tmap sensor and that totally solved the problem
Now that I have no more issues do I need to fix all those changes you guys suggested for the user adjustment page?
Default 01-18-2017, 10:28 AM
Set user adjustments back to default
Default 02-15-2017, 01:01 PM
I had some trouble finding a straight answer on what the default user adjustments settings should be but this is what i came up with. Do these look correct?
Default 02-15-2017, 02:30 PM
Looks fine to me.
mardaozo's Avatar
mardaozo mardaozo is offline
Car: Bimmer 335xi
Default 02-08-2019, 02:56 PM
Im so sorry for opening this thread again, but im having just the exact same issues as the guy who created this post, i replaced the tmap sensor and im still having issues, but here's my question,
Which one is considered Tmap sensor? The one that goes on the Intake Manifold ? or the One that goes on the Charge pipe ?
im am a little bit confused ... , i ordered the one that goes on the Intake manifold and it is arriving tomorrow, (genuine) , but i see everybody talking about 4 or 3.5 bar sensor, and i think that sensor is the one that goes on the charge pipe????
Thank you so much
Car: guess...
Default 03-26-2019, 08:44 PM
The TMAP sensor needing to be changed in in the charge pipe. Confusing cause both sensors have the exact same factory part number. Think the 3.5 bar sensor number is 7843531-01
User179_RU User179_RU is offline
Car: '08 BMW E92 335i
Question 2ABD code - 04-22-2019, 06:52 AM
Hello,
I'm new here,
I have problem with 2ABD code, after i installed BOSCH 4 bar sensor,
I did not move the pins in the connector(I am not sure if i need to relocate them)
And the car seem do not like the new sensor.
If i was right, the sensor should go to the charge pipe, but i tried both installing on the charge pipe, and Intake manifold. And only the installation on the charge pipe would bring on 2ABD code.
And if i need to move the pins in the connector, how should be done?
please help!
