mcneely.logan mcneely.logan is offline
Car: 2015 Mini Cooper S Hardtop
Default 2015 F56 Error Code - 10-01-2016, 10:27 AM
Terry,
I've been driving my F56 with the JB4 in map 2 for about 2 months now with no issues but today I got my check engine light and the following error code: "104302 absolute pressure sensor, intake manifold, plausibility, caster: pressure too low." Any ideas on what to do about this?
Default 10-01-2016, 11:39 AM
I've seen that one before, not sure on the cause yet though. Running the latest posted firmware? What are you doing when it comes up?
Default 10-01-2016, 12:59 PM
I downloaded the JB4 application for my Mac two days ago and logged a few pulls last night. Then today I drove about a mile to the store and then came back out and my check engine light was on. How do I know what firmware my JB4 is running? I haven't updated it since I got it when it first came out.
Default 10-01-2016, 01:13 PM
OK. I read how to update the firmware. Is the Mini_B38_B48_OBDII_2.hex the most up to date firmware?
Default 10-01-2016, 02:08 PM
Yes that sounds right.
Default 10-01-2016, 02:11 PM
OK. I'll update it and see if that helps.
Default 10-01-2016, 05:20 PM
I updated the firmware and cleared the code. I'll see if he returns but I drove it around the block and it seems fine. Couldn't tell a difference at all.
Default 11-03-2016, 06:19 PM
Terry, the error code is back. Any idea on what could be causing it?
liveevil liveevil is offline
Car: F34 320i
Default 09-28-2017, 01:25 AM
Hi did you manage to resolve it? I have the same code intermittently on my n20 engine.
Knock-knock Knock-knock is offline
Car: Cooper S hardtop
Default 05-23-2019, 05:15 PM
I replied to a post earlier about guage not working, I updated the firmware but no fix. I just had the same engine code trip about an hour later 104302 absolute pressure sensor. The JB4 is acting a bit crazy.
