(#76)
glachhman glachhman is offline
Car: 07 335i
Default 02-05-2016, 05:07 PM
which bumper shrouds you using?
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 02-05-2016, 05:14 PM
Not sure what you mean when you say "bumper shrouds." Please explain.
N54 Powered M5 Wagon:
Car: 07 335i
Default 02-05-2016, 05:36 PM
Sorry meant more like ducts off the front bumper for the cooling, or do you just have nothing attached?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-05-2016, 06:21 PM
Gotcha, none right now but I did trim and blackout some stuff to make it looks cleaner. In the future it will run the shrouds from ER.
Evan
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-12-2016, 11:16 PM
Dedicated tablet for the car
One of the led clusters in the tail lights were on the way out. Both units are at full power in this photo
Replacement arrived
Time to mod
Much better
Stock vs Not-Stock
Only 1 out of the 4 tails are modded, can you guess which one it is?
Much better
It is going to look so good
I did some testing to confirm output after the mods. My goal is to improve aesthetics and function simultaneously and I believe this mod checks both boxes. The chrome bowls for the turn signal were left chrome so the LEDs operate with 100% reflection and since the trim around the chrome is painted black is offers greater contrast and "pops" more when flashing. For the brake lights the oem bulbs work well and have a more uniform effect from the bowls but I feel like the LED bulbs and the intense light they omit rearward grab my attention very well, again the black contrast helps them pop.
TOP: Off
MIDDLE: Brake Only
BOTTOM: Brake + Signal
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-29-2016, 12:54 PM
Center cap was once lost and now is found...
BigTwigg's Avatar
BigTwigg BigTwigg is offline
Car: 08 335i MT
Default 02-29-2016, 04:34 PM
Flashing Jb4 Integration map
1. Is that a B5 wagon?
2. What did you mount the tablet with?
08 335i MT, JB4, MHD, ***, ER Comp. FMIC, ER Charge Pipe, Forge DVs. Custom Alcantara/ Napa Steering Wheel. RB inlets (when I get time)
-Save the Manuals-
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 02-29-2016, 04:50 PM
What did u use To mount the tablet with?
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
ucsbwsr's Avatar
Car: 535xi Wagon
Default 08-15-2016, 10:33 PM
Good eye, it is a B5 S4 Avant.
Mountek is the tablet mount.
Sorry for the delayed response, please see above.
Matt's car has been running strong, daily driven at 26psi. I have been acquiring most of those miles since he is gone competing in Rio and my E61 is still under construction.
The car received a new oil change with Shell Rotella 5w-40 along with some new Redline MT85.
Evan
Draining old MTF
"Lifetime" fluid, lol
The new Redline fluid for comparison
tan_rich tan_rich is offline
Car: E92 335is
Default 09-15-2016, 12:43 AM
Subscribed!
Hopefully I see you around HB again!.
Always nice to see a fellow n54er.
DaZuc DaZuc is offline
Car: 335i xDrive
Default 09-17-2016, 09:30 AM
TOP: Off
MIDDLE: Brake Only
First, just wanted to say damn what a thread!
Im interested with what you did with the taillights.
In these 3 pics only the right tail is modified?
Car: vw passat
Default 09-17-2016, 03:42 PM
i just realized NY plates in Cali. im in NY and would love to see this beast in person. beautiful wagon. cant wait to see what yours does with PI. also now that you have driven a single and yours with the hexons, which do you prefer?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 09-19-2016, 09:38 AM
In those pictures there are 4 sections of tail light, only the fourth (outer right) was modified with black paint. I was going to do the complete tail lights but the inner sections which house the reverse lights were not cooperating when I was attempting to open them.
The 335xi has NY plates but it was out in CA for a bit as the owner (who lives in NY) works in CA for the summer and this is his car for that season.
As far as hybrid turbos vs single, personally I much prefer the fast spool of the hybrids for a daily driven car. The single turbo is definitely fun with the run-to-redline and power potential but for the street it is a big excessive. Quick spool, accessible power, and 550-600whp is a great useable setup for a street car IMO. The powerband and spool of the new VTT GC Lites look to be about perfect for my intended use.
Evan
ucsbwsr's Avatar
Car: 535xi Wagon
Default 04-26-2017, 09:59 AM
I posted this elsewhere on the forum but not in the build thread, I whipped up some custom headlights for the E90. They feature Porsche 997 projectors, LED corner light, and an angel eye delete amongst other things.
Evan
[IMG]https://lh3.googleusercontent.com/Pb8ELG0RYTn6Ow9DoZjlW8dG4HBd5BGVDKdDQlRokE56M74Ums VEIU1Wtv1jV8uvDQ__azNkYrDbjxvrgPJSWb8ivu-yRBsb9f-ws_-CsGdO1lYA869DYbMD9BgqeVaTmxK7IYoexOU_eIYENUWPQ9vSm 4pZjErTI91yMIwBsErON518GU6mMnx0ayxEFa3iw-UBLn3NabEfqi0l1e05HQlIr2ISxiTy-0V-Z5GI0rM9v3V4sBB767OAdEGfx4ZWEdwlHULIopelfSceH_rPAq pw1SSyTs88C2V0u3b10NxMY1PhUxItLfMeVVzj6EMoL0YYLbL2 VD6AacoTlpuF2ReGlCfMSkqKylmtVccvy1IJJseSHIibJsFC7s JYnzDsoL5cAVhP9bsnz_ahQMwkFKM-VUrQoWJ9nFN7hJkjpuQzQGSOUNV33boXja-RN_IVz6otB8_Wi-KV_ezwmvcXim6RKT-1Dizv0rM1HYS__nha8V94ruYvXE9V5lCBHV0c1HNm3k_YSbKyZ 1tymJDl57sOejn8HhYkbmSwiAvGIXyPWuBA0Kf5Evft7***3xP NkQnvVsxkmkoOgVX_b-VnFwH-V11TnljCdyOc0YD9eWIkdDMnPjnT8A=w1318-h988-no[/IMG]
[IMG]https://lh3.googleusercontent.com/xlnv1iF42dcsxOtRa94-6D***LqbD0AjNg2FpcYqCoUNSMupfytuE7RHv6HaLwDUi45TdK CGWPnDFGG-KoKq1oNpsht6NgeM-J2VMJT-pn_Tl4zkk-VYia64hIdqWlthAfJvmaPs9MRmPxcTkmHttJbWUer6X6WAlHIu Xq21hGdw63z92bqJBF7Pd9G1c5yMWwdnNx6mQhmasBUXfcSMlK 8IxswK76hfE__gyvwYpnWE7jGpv002v8222tACBa7YRNvPUPYe KKVYGOiODCoQTo6ImGXHz7QjGx_Rz60SbGvKuD7MOZNv6RNrA3 qz2d91XY8Qt14fLKR2xzDk6LBj883xCB4jjErUcml04I8HWupl xaBlpHcj6R9gZrKsrbTpWJ60TYXJ0fRg7GNvDx-odA_kArnn7iHWCZuKw67XE_Emjex_szgYnsqGg1eIANqdahov4 c7X41sqp4yzJyC8MMLChV8SZs02bEIwY-oM5Apr1hqna****iRMSbul8qkLkWZA7djkPspaB0_x99gpcGpx fQKCnHQvLL1e0jRNaXac8Pj7iEr4MKTLGIQufRfnBOpnA9WWfM O37ayvcImXaPEfTHDyXC4gSCmRvS3_2FVNCoJ82VgMwg=w1318-h988-no[/IMG]
ucsbwsr's Avatar
Car: 535xi Wagon
Default 04-26-2017, 10:23 AM
All good things must come to an end.
The E90 was shipped back to my buddy's house in New York. While I was storing the car it was a nice mutually beneficial situation where the car got a lot of much needed attention (and free labor), as a by product I had access to use this beast as needed while my E61 was on jack stands for 12 months undergoing surgery.
Some Final Thoughts
While big single turbo setups personally aren't for me in a daily driver, which is confirmed after getting my wagon back up and running with it's hybrid setup, I certainly see the appeal and the addiction to a big ST car. Once in boost the way this thing covers ground is impressive, it never made it on a dyno but considering the mods, boost, etc. I would guess this thing was right around 600awhp.
Aside from some inconsistent ethanol cold starts the engine was flawless, it never had a misfire and never went into limp mode once which is pretty impressive, oil temps would quickly get up to 220-230F but would stay consistently right around 230F no matter how hard I drove (didn't track, only street pulls). The upgraded ER race coolers did a great job.
The car was driven hard but never abused, 1st gear was limited to 17psi, 2nd was 22psi, 3rd+ was 26psi, and the AWD system did a great job handling the power. Car was rarely given full beans in first, most pulls were 2nd or 3rd. Traction control never intervened ever since the car always hooks up with the R888s. Spec 3+ and MFactory SMFW never hinted at flinching. With the amount of power and grip available there is no surprise that something must give and near the end of my time with the car there is a slight wobble which developed and my hunch is it's from a front CV with excessive wear.
What this thing really need to become a true weapon is beefier suspension control arms, bushings, sway bars etc. to better handle all the forces the car can dish out.
Fun car, glad I had the opportunity to work on it and drive it as much as I did.
Evan
