Tech513's Avatar
Tech513 Tech513 is offline
Default Codes 2ABC and 3100 at start up, not consistant. - 11-08-2015, 04:21 PM
New to posting on this forum but have been having some trouble with getting codes 2ABC and 3100 at start up. Usually accompanied by what feels like a random miss while cruising about 70 to 80 mph. I have the g5 ISO updated. The car has 163000mi on it with the original turbos. I am not getting the 30ff fault, all vacuum lines are 3.5mm silicon lines. New epdws, replaced the boost pressure sensor, running er charge pipe with hKS bov. Has anyone ran across this issue before?
07 E90 BMS DCI, ER CP, HKS BOV, MHD BEF, JB4 G5 ISO with anti lag, Alpina b3 flash, Hexon stage 1, Hexon inlets, fresh rebuild with over sized OEM pistons, thicker head gasket, E46 M3 Trans mounts, Fuel It stage 2, IS engine mounts.
Default 11-09-2015, 09:05 AM
2ABC is an electrical fault. Photo of JB4 board?
Tech513's Avatar
Default 11-09-2015, 05:26 PM
Here ya go.
Default 11-09-2015, 05:44 PM
Doesn't display, must be too large.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 11-09-2015, 05:46 PM
Since jb4 update 29x I get the odd same codes. Only ever on start up...What do you use to log? PC or android app? If its the android is it connected when you start the car?
Russjonesr's Avatar
Car: Bmw e92 335i
Default 11-09-2015, 06:05 PM
Just to clarify. I couldn't understand why I never got the code in the morning leaving for work at lunch time to the gym or on the way home! Only ever after restarting the car. Initially I presumed heat was having some effect, however I narrowed the issue down to the fact that the android was still hooked up! To and from work, I start the car link the android and hit connect...no problems
It only ever happened when I stopped to pick up my son, so the android was left connected to the jb4. I now always physically disconnect the android and haven't had the code since
Tech513's Avatar
Default 11-09-2015, 06:14 PM
Samsung tab 2 I think. But I don't connect it until I have started the car. I'll try to get a better picture tomorrow when I pull it into the shop.
SoCalHarley SoCalHarley is offline
Car: 2007 335i e90
Default 01-16-2016, 07:57 AM
I just started havin the same problem. Only on start up. Did you ever resolve this.
2007 335i e90 Auto [/FONT]
JB4 G5, xHP Stage 3 TCU, Wagner FMIC, VRSF DP's, Corsa exhaust, Mr.5 intake, 25 row oil cooler, ST coilovers, Hotchkis swaybars, rear subframe inserts, Dynavin N6, 3M brushed black metallic interior trim , Apex PS-7 wheels, Hankook Evo2 235/35/19 & 275/30/19
Daily Three Daily Three is offline
Default 01-21-2016, 01:00 PM
fairly common issue i believe. i get it often if i have my tablet plugged in on startup.. happened more frequently when i updated to the new firmware, but i think that happens most times i update the firmware
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 02-10-2016, 06:40 PM
Just happened to me for the first time today. I'm on pc hooked up before starting as I was changing some Afr bias values.
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020, stock everything else, 374.9 rwkw Mainline Dyno Aus
sirfredi's Avatar
sirfredi sirfredi is offline
Default 02-11-2016, 12:38 AM
I have the same faults.
we are a lot. terry should investigate the problem to give a solution as soon as possible 8)
Car: 2007 335i e90
Default 02-12-2016, 11:52 PM
Same issue here after upgrading to 31.8 firmware. I just updated to 32.1 so lets see what happens.
Car: 2007 335i e90
Default 02-14-2016, 08:39 AM
Same problem. All of this started when I updated from earlier version 27 firmware. Zero issues until the 31 firmware installed. My car is a pre 03/07 build. Any ideas?
Default 02-15-2016, 01:56 PM
Verify all of your settings have been returned to the defaults. Then do a couple logs and post those.
steve.kodra steve.kodra is offline
IXLR8
Default 02-15-2016, 02:48 PM
When I had the issue and resolved it by fine adjusting the speedo 12 settings.
Tech513's Avatar
Default 02-15-2016, 05:43 PM
These codes set when the tablet or computer is connected at start up. Simcoe I have switched to connecting after start up I have not had any problems with my vehicle or software used.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 02-16-2016, 04:56 AM
See point 6 above...and as per Terry on another thread discussing the same issue
"The P3 and the JB4 may fight for CANbus bandwidth causing odd problems like this"
Do not start the vehicle with the JB4 connected to a PC or Android.
Default 02-16-2016, 08:22 AM
We start our cars all the time with PC's and JB4 mobile connected, never been an issue.
However, a P3 gauge, something in the OBDII port, or anything that interferes with the CAN is a big issue.
Car: 2007 335i e90
Default 02-17-2016, 01:22 PM
What did you set speedo 12 to?
I have a jb4connect bluettooth Rev2 connected. Any know issues with this?
Default 02-17-2016, 09:11 PM
We run Rev 2 on two of our cars...no issues.
DSCOFF's Avatar
Car: 335i coupe N54
Default 02-17-2016, 10:57 PM
Since that day, this issue has to resurfaced for me..
DSCOFF's Avatar
Car: 335i coupe N54
Default 02-18-2016, 05:03 AM
Actually just happened to me again before as I forgot to disconnect my Android jb4 device before starting engine
Car: 2007 335i e90
Default 02-20-2016, 08:42 AM
Had the car on map zero for two days and the codes came back. Would this indicate it is not the tune but an electrical connection?
Car: 2007 335i e90
Default 02-20-2016, 02:23 PM
Well I undid all of the JB4 connections to the ECU as well as the TMAP sensor and sprayed them with electronic contact cleaner and reinstalled. All back together and runs well. Let's see if this was the issue...
Car: 2007 335i e90
Default 02-22-2016, 07:34 PM
All good for 2 days then I left the Jb4 mobile app connected and shut the car off. When I went back out and started the car back up the codes and half engine popped up. This has to be related to a bug with the mobile app and failing to disconnect before shutting the car off. Can't be a coincidence...
