Default 12-02-2015, 02:24 PM
Nice result from our Australian JB1 user Danny. 12.1@114.6mph. Mods are VWR600, APR turbo outlet on stock wheel setup. Map 1 with some ethanol was used. The exit shows the power the JB1 can produce. Car is a 206kw version.
Mike@N54Tuning.com Mike@N54Tuning.com is offline
Car: 07-335i
Default 12-16-2015, 09:46 AM
Nice run..
Mike
www.n54tuning.com
Default 12-20-2015, 11:37 AM
Nice result on this 206kw version 7R DSG with a 11.9@113mph. Car ran dp, intake and semi slick tires with stock weight. Temps where 102F so exit suffered a bit on the day and I guess times to a certain level.
Default 12-27-2015, 03:08 PM
Well done to our 7R Burger Tuning JB1 user cupersteve running a 11.7@114 at Sacramento yesterday on 91+meth, JB1 piggy back, dp, intake and cooler. Michellin PSS street tires where used. The car run full stock interior. Car showed major consistency with the car being hot lapped with no cooling allowed.
Its a pity the day was cut short as he was heading in the right direction for a better time and close to the limit of what the JB1 can give in the street trim he was in. As always we keeping our policy of customers producing the results and not us going out and running the "magic time".
A great analysis of his day at the drags can be found here: http://forums.vwvortex.com/showthrea...-793-114-69mph
Default 12-29-2015, 11:06 AM
Some heart breaker Mustang 4wd results on this JB1 powered Golf 7R. Power is at the wheels. Map 0 is stock boost power with the bolt ons. Map 1 shows two different boost add settings. Fuel used is approximately 93US.
Default 12-31-2015, 08:01 AM
Some Dynojet results.
Default 01-20-2016, 05:32 AM
Some nice results on this S3 with JB1+drop in filter running 91 with some octane booster. Average baseline on this dyno is 272whp. Car pushed 317whp on two consecutive runs showing average delta of 45whp. Measurements where done on front wheels with map 1 and +5.2.
Default 02-19-2016, 05:30 AM
Well done to JB1 user David. He went out with his 7R in street trim full weight with a DP and intake using a E85 mix and nearly got the exit speed record for a 7R. Major traction issues with a bad 60ft killed the time but I am sure he will go back prepared.
Default 03-10-2016, 04:52 AM
Some nice gains on the 206kw/280hp version of the 7R. Wheel gains are 59whp and 56ft lb. Car used 91oct with intake. Dyno is at 5600ft altitude.
Default 03-16-2016, 04:16 PM
Same dyno on this Audi S3 8V using map 6, note how the torque is moved up the rpm range with a less conservative spool.
Gains of 49kw & 89Nm ( 66whp and 65ft lb) at the wheels with 95 Ron/91AKI pump fuel. - Stock power with ******** (189wkw & 401Nm)
- ‪#‎JB1‬, full exhaust + intake (238wkw & 490Nm)
Default 04-12-2016, 03:08 PM
Some nice results out of Bahrain on this Golf R, our dealer Aryan Xtreme working some magic. Car had JB1, down pipe and intake on 91 on 4wd Dynojet. Power at the wheels.
Default 04-29-2016, 04:52 PM
Some good results of this 2015 Audi S3 with some bolt on mods and our JB1 tuner.
343whp and 346ft lb on 4wd dynojet using Canadian 94.
Default 05-16-2016, 05:46 PM
Got some links from a JB1 users sent to me from Sweden on his manual R powered Seat Cupra 280hp version. He really dished it out, runs are from 30mph-150mph. Map 1 was used with 5.2 and a slight ethanol mix, car has dp and intake.
Leon Cupra JB1 M6 vs BMW 1M Cobb 400whp. That's what you get if you dont JB4 your BMW.
Leon Cupra M6 vs BMW M5 E39
Leon Cupra M6 vs Golf R MK7 DSG stage 1 Flash
Leon Cupra Manual vs DSG both JB1 cars with slightly different settings. The DSG camera car ran map 6 with 5.4 that was a bit over board for his fuel so it let the manual take the win.
[video]laXmqQ0kwzc[/video]
Default 05-31-2016, 12:40 PM
Some nice results on this JB1 R with ******** and intake using the default map 6. Dyno is a Maha and power is calculated at the flywheel. You can see how the low torque map setting keeps the spool in check creating a torque peak higher up in the rpm range which is great for manual clutch preservation.
Default 06-07-2016, 03:48 PM
Stock R with JB1 only in the UK running default settings at the http://www.theperformancecentre.co.uk/
Default 06-08-2016, 02:36 PM
Another great result on the JB1 power Seat Leon Cupra 280. Car ran with 98Ron, JB1 plug and play and BCS Powervalve. Car was tuned at www.theperformancecentre.co.uk
Default 07-08-2016, 05:47 AM
Skoda Superb 2.0TSI 280hp with JB1, dp, intake and cooler. Power is measured at the flywheel. 90hp gains using 98Ron.
Default 07-10-2016, 09:52 AM
Nice results by The Performance Centre in the UK on this stock S3. 98Ron JB1 only car on map 1 5.2.
Default 07-11-2016, 08:17 AM
Our dealer in Bahrain (Aryan Extreme) recently had a opportunity to do some back to back 91 vs 93 octane testing since they started getting 93 at the pumps soon. Car has JB1, intake and down pipe running map 1 4.8 in both runs. Dyno is 4wd dynojet.
pigwet pigwet is offline
Car: F80
Default 07-16-2016, 03:18 PM
George,
I live at ~6000ft, 0% humidity, with highs in the 95-100F. I too have been hearing the fluttering/surge between 3000-4000rpm on my DSG Golf R under high-load high-throttle conditions. I don't recall if this happened when it was cooler so I'd be interested hearing your input on a) do I need to worry about this at all b) is this phenomenon affected by temp and c) differences at high altitude.
From what I understand my turbo has to spin faster to reach the MAP target psi up here, so it is a bit surprising that it still has the flutter issue this high up given that it likely takes longer to spool up.
I adjusted map 6 to the following and was only able to completely get rid of the fluttering if I set 3000-4000 to 0. Even a setting of 1.0 would cause it. I didn't bother playing around with 2000-3000 and simply left it whatever 3000-4000 was set at. I started with a more moderate ramp at 4000 but eventually ended up just making it a step function.
Do the other flash tunes have this issue? I had a JB4 in a BMW and it didn't have this issue. Is it a turbo specific issue? Is there a bolt-on part that will mitigate it?
RPM: Boost:
2.0..... 0.0
2.5..... 0.0
3.0..... 0.0
3.5..... 0.0
4.0..... 4.0
4.5..... 4.5
5.0..... 4.8
5.5..... 4.8
6.0..... 4.5
6.5..... 4.5
Default 07-16-2016, 06:14 PM
Originally Posted by pigwet
George,
RPM: Boost:
2.0..... 0.0
2.5..... 0.0
3.0..... 0.0
3.5..... 0.0
4.0..... 4.0
4.5..... 4.5
5.0..... 4.8
5.5..... 4.8
6.0..... 4.5
6.5..... 4.5
As the temperatures increase the ECU due to torque targeting increases the boost to compensate. This makes it easier for the car to surge. Its comes part and parcel with increased boost and torque levels low down. If you also recently fitted a air intake it will be much louder as the stock intake muffles the noise.
What you have used will work and you can revise once things have cooled down. At this stage with the upgraded turbo though and with the US having the latest revision it has proven not to be harmful.
The flash tunes have the same noise unless the file is considered low torque, no one really knows on their side what has been dialed out though due to so many revisions.
Car: F80
Default 07-17-2016, 07:00 AM
Well I guess this makes sense why VW actually lowered the pMax for different geography/climates. I imagine it is super difficult for the US since there's such a vast array of temperatures.
I was hoping you would say all you need to do is get a ____ and I could set it and forget it.
Default 08-01-2016, 05:36 PM
Good result from this 280/206kw version R. Mods are JB1, DP and intake on stock tires.
Default 08-11-2016, 12:48 AM
Another great results from a Australian Golf 7 R (206kw version). Car ran JB1, turbo back, intake and cooler on stock tires and weight. The run couldn't have gotten closer against a Stage 2 flashed R.
Default 08-13-2016, 01:51 AM
Some great results on this S3 in the UK done by our dealers The Performance Centre. Car is stock with JB1 running 98 Ron.
