Nicke90cnc Nicke90cnc is offline
Default N54 single turbo port injection fuel bias/ duty bias fine tuning - 05-14-2019, 11:45 AM
2007 e90 335i
Doc race bb 6266
Ad engineering fmic
True form technology charge pipe tial bov
Bmp port injection 750cc injectors
Bms port injection controller
Bmp stage 3 fuel pump
Precision raceworks coils
Ngk plugs gapped .022
Jb4 with mhd backend
https://cdn.fbsbx.com/v/t59.2708-21/...=5CDDE872&dl=1
Was hoping you pros can check out my log and help me with my duty bias/fuel bias and asbr settings to fine tune my set up bc I can't find much help anywhere else
Default 05-14-2019, 11:50 AM
Need to post the CSV file please.
Default 05-14-2019, 01:03 PM
Here is the csv file
Default 05-14-2019, 04:34 PM
Lets start with map 2. Set fuel open loop to 0.
3rd gear from 2krpm till redline, make sure pedal is 100% for consistent data.
Default 05-14-2019, 04:39 PM
Will do, I'll get back to you first thing in the morning with a log, thanks.
Default 05-14-2019, 09:01 PM
Map 2 fuel open loop set at 0
Wasn't quite redline I ran out of road lmk if need to do a full redline
Default 05-14-2019, 11:02 PM
Boost looks pretty decent here.
Cyl 4 looks to be making some noise throughout the pull
Imo spool can be improved a bit with DWP.
Payam- thoughts?
Default 05-15-2019, 11:35 AM
Looks good! Lets do the same now on map 3.
Then we'll start working on the duty bias to get boost on target.
Default 05-15-2019, 11:36 AM
Payam- thoughts?
DWP is at 70 so it's pretty high, anything higher and he might just have some overboosting. We'll evaluate it in the higher maps once we get boost control down.
Default 05-15-2019, 11:54 AM
So what should I do next?
Default 05-15-2019, 09:37 PM
Map 3 as Payam stated
Default 05-18-2019, 06:54 AM
Map 3 fuel open loop at 0
Default 05-19-2019, 03:34 PM
Lets bump your DB by 10 from 4K to redline
Default 05-22-2019, 09:06 AM
Map 3 with duty bias bumped up 10 from 4K to redline as suggested
Default 05-22-2019, 09:08 AM
Can't seem to reach 20psi!
Default 05-24-2019, 03:08 PM
Anyone?
