410bn's Avatar
410bn 410bn is offline
Car: M
Default Low/no boost - nasty whine under boost (video) - 05-17-2019, 01:56 PM
Hey guys.
Last night, I got into it in second gear, noticed an immediate loss of power and a whine sound under any amount of boost. It wont build more than 1 or 2 lbs now.
No smoke. If I pull the vacuum lines off the boost solenoids, no whine. No codes or limp mode. It's hard to tell exactly where the sound is coming from but it seems like it's coming from the rear drivers side of the engine. The whine doesnt sound like its coming from around the intercooler and I feel no leaks around the charge pipe.
Do you guys have any suggestions or ideas of what to check? I'm actually on vacation in OCMD so I'm in a bad spot.
https://youtu.be/RtgVkvKv5Yc
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-17-2019, 03:25 PM
Unfortunately, sounds to me like something got sucked into the turbo and damaged the compressor.
Ref:
Bad turbo on BMW 2008 N54 - YouTube
You could get a borescope on Amazon and send it down the intakes to check.
ManiN54's Avatar
ManiN54 ManiN54 is offline
Car: 2007 335i FBO stock turbos
Default 05-17-2019, 04:14 PM
Originally Posted by 410bn
Hey guys.
That’s definitely a blown turbo or turbos. Upgrade time
1/4mile 11.8@117.96 19psi
07 E92 335i (the Alpträum) | Alpine wht/ Seibon carbon hood/ trunk| M parallel wheels| street tires
FBO| modified oem airbox lid w/K&N drop-in| stock turbos/ stock inlets| Walbro 465lph LPFP| Jb4/mhd backend flash| Map 6 w/E60 No Meth| Built and tuned by me.
410bn's Avatar
Car: M
Default 05-17-2019, 05:01 PM
Ugh that's rough. They're RBs with roughly 30 to 40k on them. Question now is to get them rebuilt or go a different route...
ManiN54's Avatar
Default 05-17-2019, 05:20 PM
It’s just excessive shaft-play. It’s worth looking into rebuilding.
Default 05-17-2019, 11:58 PM
RB generally has a pretty solid rebuild / upgrade policy.
I’d shoot him an email
