(#26)
TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default 05-12-2019, 02:04 PM
Hello , new here as of today and a new jb4 user as of Thursday and have a question .
Im getting hiccups at idle speed only after a short run but all else seams fine when driving ,also car is on default setup map1 .
The hiccups are noticeable every few seconds and go away under load , I do have a data cable but waiting on having my pc fixed so i can run it ( im on Chromebook now )
My car 2018 1.8T m/t and running on 93 octane .
Just wondering if there is a quick solution and what can be done to resolve this minor issue , I should be able to log into my car as of this week and check firmware etc.
georgevox16 georgevox16 is offline
Car: 2017 Jetta GLI
Default 06-14-2019, 09:38 AM
bumping your question, I have the same symptoms, but on a GLI (also running 93 on map 1 w/ JB4)
Default 06-14-2019, 10:15 AM
I did firmware update and it helps a lot , still there but now have to look for the hiccup, also I moved to map2 on 93 octane and it got better not as noticable ...and runs so much stronger on map2 but 93 octane only .
George @ BMS George @ BMS is online now
Default 06-14-2019, 10:28 AM
For guys with the idle hiccup see if this firmware irons it out. Been sending it out to individual for the past week and it seems to be mostly eliminated with smoother spool up as well.
Let me know your findings.
Default 06-14-2019, 04:00 PM
Just updated with this firmware will keep you posted and thanks for all the support.
PS loving map2 its so much smoother and keeps top end lot stronger I find , the car drives fantastic with lot less effort , just goes when you stomp on it haha
Car: 2017 Jetta GLI
Default 06-14-2019, 07:16 PM
I flashed this file and let tach come down from the cold start idle. Seems like it works. I haven't been able to test for more than a minute and now out of town with my wife's car . I'll keep you posted, but early indications are that this ironed it out. Regardless, you're a magician. Next stop, I'll see if the stock clutch can hold map 2 and maybe map 6 at some point. Thank you!! Loving my JB4.
Default 06-15-2019, 04:07 AM
Cool, its the general feedback we getting.
Will wait for a few more responses and will add the new maps to this firmware and put it up on the Gen3 main page.
Default 06-16-2019, 12:35 PM
Still got the hiccups at idle otherwise all good
Default 06-16-2019, 06:46 PM
As a test, put the brown MAP sensor connection on the top of the intake (the easy to reach one) to factory. Leaving the JB4 plug sitting out of the way, so we can see what effect bypassing that signal has.
Default 06-16-2019, 06:59 PM
will do for sure , give it a try tomorrow and let you know
thanks
Default 06-17-2019, 03:08 PM
ok so just did what you asked , car was up to temp after drive from work ..with stock MAP sensor cable plugged in car has no hiccups at all once JB4 MAP cable gets plugged back in hiccups are back. I can say that they are lot less obvious with the firmware update but unfortunately do exist , as long as no harm im not to concern since they are very small but if you have a fix that would be fantastic.
Default 06-18-2019, 04:14 AM
As a test remove that plug again and use some ear buds (cotton buds) and see if you can clean the pins on the sensor. Sometimes there is some sealant they use on the plugs and it can cause similar. If the car has high mileage also worth pulling the sensor and giving it a clean with some petrol if its covered in oil.
Default 06-18-2019, 05:02 AM
Well the car is new just over 6000km on her so can't see the sensor being dirty but will recheck the connector and can add electronic grease to plug end possibly .
Thanks for the help .
Default 06-18-2019, 02:10 PM
OK that is what I wanted to know, so it's definitely related to the brown connector signal?
Default 06-18-2019, 02:22 PM
Yes definitely the Brown connector , so something is up with that signal , the car in new with just over 6k .
Default 06-18-2019, 05:44 PM
While the brown is stock, do a log your normal performance map so I can see what difference it's making on the tuning side too having that one connection only factory.
Default 06-18-2019, 06:09 PM
Ok will do but wont have it till next week , now can I use any USB extension cable with the data cable to run the laptop inside car for logging ..?
Default 06-18-2019, 06:14 PM
Sure!
Default 06-18-2019, 06:22 PM
Sure!
Awesome and thanks , will have it for you soon as I can ...this week little crazy Ill try Sunday or early next week .
Car: 2017 Jetta GLI
Default 06-25-2019, 12:34 PM
Been running it daily for the last week, it's so much better. Like another member mentioned in another thread, i actually connected to the JB4 app in a parking lot because I wasn't sure if it reverted to map 0; it's that smooth.
