rharden rharden is offline
Car: Ford Raptor
Default Firmware update order and other questions - 05-06-2019, 06:27 PM
In the Ford 3.5 EB sticky fire are updates, there are three. Do I need to do them all in order or will just loading the latest #3 give me everything in 1&2 as well? I have loaded #3 successfully.
I have a 2018 Raptor with a Roush CAI and the JB4 with the connect kit. I have changed the plugs to the Motorcraft SP542 iridium (cooler) plug to handle the CAI and the tuner. I run only 93 octane gas. When the JB4 is not on, the throttle seems fine, when JB 4 is on Map 1,2 or 3 the throttle seems to fall flat initially and then come in strong, does the same when in sport mode when in throttle, off and back on. Suggestions? Many thanks
Payam @ BMS Payam @ BMS is online now
Default 05-07-2019, 10:28 AM
Only need to update to the latest file which is this one:
JB4_F150_3.hex
Can you get a log on map 0 and map 1 so we can see whats going on?
Car: Ford Raptor
Default 05-12-2019, 10:01 AM
Hi Payam
I waited to respond as was having truck in for service and some harsh shifting concerns in sport mode. The dealer did a transmission reprogram (TSB 18-2274), and it appears to have made the throttle more responsive and the shifts faster, seems to have corrected the problem of the stumbling that I alluded to in my original. Thanks
Car: Ford Raptor
Default 06-16-2019, 06:06 AM
Decided I will go ahead and send you the logs - Map 0, 1 & 2; however, not sure how to attach the .csv files within a message? I see where they can be emailed. To recap, I have a 2018 raptor with a Roush CAI and the JB4, and run only 93 octane fuel. On map zero obviously the truck runs as one would expect. On map one I seem to get some Drago hesitation and on map to no throttle hesitation but some wastegate rattle on the top end, or I believe it is that. Wanted to send the logs, can you advise how to do that please. Thanks
Default 06-17-2019, 08:34 AM
You can upload them here or email me directly. Payam@burgertuning.com
To upload the CSV file here, click go advance under the post box. You'll see a paperclip icon, and from there you can attach files.
