Mikeroo88 Mikeroo88 is offline
Car: Kia stinger 2.0T
Default JB4 installation stinger 2.0 - 05-10-2019, 09:33 AM
Does anyone have any videos or good pictures of the connection to the OBDII.. videos provided are on the GT and I don’t have wires on same spot seen in video and wire doesn’t reach far enough inside the vehicle from behind the E break to make connections to the OBDII from inside. Not mechanically inclined need help
Default 05-10-2019, 09:38 AM
Also tried using purchased wire as an extension but connection still not showing readings on the app.
NLJ NLJ is offline
Car: G70
Default 05-10-2019, 11:27 AM
There's a little crevice where the fender meet the hood. You see it when you have your driver door open, see if you can push the small square through. Otherwise you will have to push it through the grommet in the firewall.
Default 05-10-2019, 11:31 AM
I went through the grommet however the wire is not long enough to reach the white wire of the OBDII. The JB4 is on the passenger side to reach the O2 sensor. I tried buying wire and using it as an extension but still not getting any feed to my app
Default 05-24-2019, 05:28 PM
Sorry I missed this thread... Did you get it sorted? if not post photos so I can better spot what the issue is.
TStaino TStaino is offline
Car: 2109 Kia Stinger 2.0T AWD
Default 05-31-2019, 06:03 AM
@Terry @ BMS do you have any pictures of exactly where the fuel wires go in the 2L Stinger?
I’m not the most mechanically inclined so telling me “it’s on the intake manifold” is like speaking Chinese to me...
A quick picture of which exact wires I am messing with would make me feel a lot better about puncturing holes in them.
Thanks again for an AMAZING product!
NLJ NLJ is offline
Car: G70
Default 05-31-2019, 07:34 AM
Back of the engine towards the firewall from the passenger side:
N54Tech.com - International Turbo Racing Discussion - View Single Post - Kia Hyundai JB4
Default 05-31-2019, 04:59 PM
Thanks Terry. I see the first wire.. but not sure where the second one goes..
I watched the video you made of the 3.3 Stinger install, but the second wire goes not the driver side of the engine, and my driver side of the engine doesn't look like that... so I'm half way there, but still half way lost...
Please see attached.. the first picture is where the "short" wire goes, right? On the white wire?
But the "long" wire... ? Could it be the second picture?
Default 06-01-2019, 07:40 AM
Orrr am I only supposed to be using one wire because I only have one turbo?
When I said I wasn’t mechanically inclined, what I meant to say was..
n0o0o0o0o0o0o0o0o0b!
NLJ NLJ is offline
Car: G70
Default 06-01-2019, 07:47 AM
Only long wire on the 2.0t.
Default 06-01-2019, 07:59 AM
Thank you! And that goes on the white wire in my first picture above?
NLJ NLJ is offline
Car: G70
Default 06-01-2019, 08:48 AM
If that's the back of the engine on the passenger side towards the firewall, then yes. It connects to the #2 label on the harness plug.
There's an image of it a few pages back on the main page. Sometime in April.
Default 06-01-2019, 08:59 AM
It is! Thank you again!
