Hb_z Hb_z is offline
Car: Bmw 750li
Default N63 using ms109 map 6 setup - 03-12-2019, 06:54 PM
Hi guys i want to reach 20psi or more on my n63 can you help me with map 6 setup.
P.s I uploaded a log of map 2 running ron 95.
BMRDude BMRDude is offline
Car: 2012 550ix
Default 04-22-2019, 10:09 PM
What help do you need?
Your timing looks good, but you have pretty large boost differences between banks to sort first.
Car: Bmw 750li
Default 04-23-2019, 03:06 AM
How much boost do i put on each rpm and the max psi i can go
Car: 2012 550ix
Default 04-23-2019, 06:30 PM
you have to determine how much boost your car can handle. Every car is unique.
Your starting point is your Map 2 log. from this log you can see what your car did at each rpm and try adding 1 or 2 psi and then do more runs to see how the logs look and how the car performs.
it is trial and error but don't get too aggressive. go one step at a time.
you will need to learn how to read your logs. this takes time and practice. it is not simply plug and play.
In particular, you need to know how to read the timing, afr, throttle, trims, and make a judgement about how stressed your engine is vs how hard you are willing to push it.
This N63 engine has proven to be more difficult so many decide to play it safe and stick with Map 2.
Car: 2010 535
Default 06-19-2019, 07:47 AM
why are there large boost differences between banks on Map 2?
