(#51)
Default 02-23-2017, 10:46 PM
You should be fine on map 0 with the N20. We did it, no issues.
The code will be an issue though. That sounds like a bad connection or bad adapter,
JUST8AV8's Avatar
JUST8AV8 JUST8AV8 is offline
Car: 07 e92 335i
Default 02-24-2017, 11:17 AM
Thanks Steve. My tuner thinks it might be a faulty adapter as well.
09 335xi AT, Pure Stage 2 'DD' turbos, JB4 G5 ISO w/anti-lag, MHD Trebila tune, xHP Stage 3, Fuel-It Stage 2 LPFP, NGK 1 step colder plugs, BMS meth kit w/dual cm7, BMS DCI, VTT inlets/outlet, RB PCV valve, BMS OCC, N20 tmap, Cyba Scoops, Lux H8 160, VRSF 7" FMIC, VRSF **, Custom exhaust, VRSF Chargepipe, GFB SV50 BOV, ER Sport Series Oil Cooler, UUC front sway, M3 rear sway w/powerflex bushings, BC Racing coilovers, Hawk HPS 5.0 brake pads
Default 02-25-2017, 10:28 AM
No problem!
JUST8AV8's Avatar
Car: 07 e92 335i
Default 03-01-2017, 10:36 PM
Just wanted to give everyone an update that might have the same issues I had. Since I'm at high elevation (4,200+ft) My tuner made adjustments(not sure what) to my BEF per Terry's suggestion and now the 3100 & 2ABC codes are gone
If you have a N20 tmap, are at higher elevation, and are getting these two codes, you might just need a little tweak in your BEF.
1FastT2 1FastT2 is offline
Default 03-02-2017, 06:42 AM
Originally Posted by JUST8AV8
Any thoughts? I didn't have the otg cable plugged in at start up and it still pops up with the two codes. I then decided to plug the usb directly to my computer to see if the jb4 app or otg cable was the issue. The 3100 and 2abc still pops up
I don't understand why these codes won't go away. I originally noticed the codes pop up when I first installed the 4 bar sensor a while ago so I got a replacement and still no luck. The 4 bar was also very inconsistent, unresponsive, and jumpy(main reason I got a replacement). I decided to give the n20 3.5 tmap a try and it was much better, however, I still got the two codes. Car drives fine and everything works. It's just these damn codes. I'm stuck.
This sounds like the exact path im going down right now. I already had a 4 bar replaced for it to work for a few days and now the 3100 and 2abc codes are wreaking havoc. I'm at sea level so your fix may not apply to my situation.
2008 e92 335i 6MT - On3 Performance Single Kit w/Precision 6266 Gen 2 | VRSF 7" FMIC | VRSF Chargepipe w/HKS BOV | JB4 w/Bluetooth & 2 step and MHD BEF | BMS Meth Kit 2x CM10's | Fuel It Buckless Stage 2 Pump | ADV Sensors | Trebila Tuned
JUST8AV8's Avatar
Car: 07 e92 335i
Default 03-02-2017, 03:15 PM
Do you use the jb4 app? With otg cable & usb cable or with bluetooth?
Default 03-02-2017, 03:27 PM
I'm using the app via bluetooth. The last time I drove the car it was reading a constant 19+psi even at idle. I had to limp it home because the car was just dumping fuel.
Default 03-02-2017, 04:00 PM
JB4 log?
Default 03-02-2017, 04:12 PM
This is really the only one that shows the issue. All the other logs are all over the place. You can see boost never comes down after this run. Boost was set at 17psi
Default 03-02-2017, 11:11 PM
Set FF to zero and do a few adaption runs.
Default 03-05-2017, 05:04 PM
Unfortunately this had no effect. In addition to setting the FF at 0 I also reflashed the BEF and reset the adaptions.
While this did rezero the TMAP back to 0 PSI at idle it didn't last long. At ldle I now see about 2.7 psi of boost.
I would imagine the TMAP is close to the most important sensor that needs to be full proof I really need to get this squared away.
Any thoughts???
Keep in mind this is my 2nd 4 bar TMAP sensor. The 1st one worked appropriately for about 200 miles and this last one hasn't seen 50.
EDIT: I'm now having a 2ABD code
Default 03-06-2017, 06:52 PM
Any thoughts???
BUMP FOR HELP!!!
Default 03-06-2017, 10:55 PM
Did you take a log with the new setting? Were you overboosting as bad?
2abd can be caused by a boost leak.
Default 03-07-2017, 04:21 AM
I have a log at idle I will post up later today showing boost while sitting stationary. Obviously not correct.
The thing is, its not over boosting. Its caused from a false reading from the sensor. Whether its the sensor or the jb4/bef or a combination of both somethings not right.
Thanks for your help.
EDIT: I feel this issue is different from the other an may need its own thread.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-22-2017, 09:11 AM
Started to have the same codes at start up in the last few days, no change done to the car,
I switch off and delete error and turn on again and all back to normal.
I have the Bluetooth connected and powers via separate fused power and always on when ignition on.
Noticed if I have the jb4 mobile app were running perior to shutdown even if i disconnect the app this error popup next day morning, if I wasn't using the jb4 mobile app then I don't get the error next day.... strange
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 09-23-2017, 10:46 AM
Which TMAP are you using?
For anyone else with this issue:
Please send an email to support@jb4connectkit.com with the title (2ABC and 3100). In the body of the message include your engine type, JB4 firmware version, your device type (iOS or Android), and if you're using a Connect Kit or BMS USB cable.
Rushan's Avatar
Car: 335i E92 2009
Default 09-23-2017, 10:51 AM
The stock TMAP
Using IOS latest on testflight, my Bluetooth connected via USB power adapter directly from the fuse box as power on with ignition.
Rev 2 Bluetooth
JB4 32_6b
N54
qwik_ss qwik_ss is offline
Car: 335xi
Default 10-31-2017, 08:20 AM
I'm getting the same codes after installing the n20 map sensor. My car is an 09 and I have the rev 3 bluetooth kit. A buddy of mine has this issues too on his 09. Has there been any solution
Default 10-31-2017, 08:55 AM
2ABC just means your TMAP signal is wrong. Doesn't tell you why it's wrong.
Sometimes it's a JB4 setting, sometimes a flash setting, sometimes the wrong sensor is installed.
Patmcl135 Patmcl135 is offline
Default 04-16-2019, 05:31 PM
Any update on this? Have been getting these codes since last year and now need an inspection sticker.
Any update would be helpful.
