MartinF22 MartinF22 is offline
Car: F22 M235i (Alpine White)
Default N55 pure stage 2 bef + map 6 problems. - 08-22-2017, 08:10 PM
Ok so I have a pure stage 2 m235i with a bootmod3 bef and jb4. It's fbo with port injection. In these two logs im running e60 fuel and I changed my spark plugs like a week ago and gapped them to .022. im not having any misifire issues but for some reason Im getting timing corrections. I've tried 3 different tuners and for some reason whenever I try flashing the car with a bef the car pulls timing. The car doesn't pull timing on stock flash however...very strange. I've attached two logs.
15' F22 M235i / JB4 / Enzo Flash / ER FMIC / ER DP / BMS intake / Dinan Exhaust / Dinan Springs / LSD
Default 08-22-2017, 09:36 PM
You need to lower your fuel biases, trims are bottoming out.
You're overboosting a little at tip in so some DB tuning may help with that. Throttle is closing, maybe torque related and DME is pulling timing?
Default 08-23-2017, 02:10 AM
Yeah Steve I know about the trims and the overboosting i just didn't care to fine tune at the time since the car was pulling timing and I know that both those aren't causing it. I think it's torque related as well. What would that entail though like what could be the problem?
Default 08-23-2017, 09:38 AM
That would be difficult to address without a flash unless Terry has some additional options he can try on the JB4 firmware. Not sure if he can or not.
Default 08-24-2017, 03:51 PM
Have they tried to address it in your flash and raise the torque limiters?
Default 08-26-2017, 07:33 PM
Originally Posted by cnm135i
Why the BEF if car is running fine without?
Well its complicated. I cant run jb4 only because the car keeps trying to advance the timing too much and then throttle closes on stock flash, so Terry is telling me I need a bef so I can control the timing.
Default 08-26-2017, 08:27 PM
I asked and they said the torque limits are raised.
Default 08-27-2017, 11:06 AM
That is correct...not sure what to do about your timing at tip in though.
Default 08-27-2017, 03:41 PM
Me either and everybody I've talked to doesn't know what I should do either. Very frustrating. I'm about to give up and return it to stock.
Default 08-27-2017, 09:34 PM
The timing has to be fixed in the flash map, period.
Car: guess...
Default 02-26-2019, 11:42 AM
Sorry to revive an oldie but I have a related question: What is the additional function(s) of the BEF's when combined/ran with a JB4 in 3.5 TMAP mode for use with the Pure Stage 2?
Is a function of BEF's to pull timing tables down to allow more boost to be run safely? If someone were to have a PS2 installed and not load a BEF to their JB4, what would happen as far as timing under boost?
I read above where MartinF22 said, "car keeps trying to advance the timing too much" and I got curious.
