Exo Performance Exo Performance is offline
Car: M3
Default 2018 Golf R -Log review request - Issue - 02-12-2019, 08:27 AM
We had a EPC light on with limp mode issue - No boost
Fuel Open Loop was set at 45 we did change it for 60 for this log...
Please review
Default 02-12-2019, 12:57 PM
Originally Posted by Exo Performance
We had a ESP with limp mode issue - No boost
Please review
Can you check the fault stored.
Default 02-12-2019, 02:00 PM
Please review
Temps in the log are below freezing. Throttle is closing white a bit, chance that the traction control is causing this as well. I would dial it back to map 1 at those temps and see what it does.
Car: M3
Default 02-12-2019, 03:58 PM
Traction control was disabled. There is no code at the moment...
Default 02-12-2019, 04:07 PM
If it is a R/S3 and specifically a Facelift or Mk7.5 set the FOL to 40 and see if the issue persists. If it does the fault again read it. It wont go into limp mode without storing a fault unless its on another module like ABS or transmission and the JB4 cannot see it.
Car: M3
Default 02-14-2019, 07:27 AM
FOL set at 40 we get a code P0420 and U1202
We found some change FUD to 90 to adress this code... What's your advise?
Default 02-14-2019, 11:48 AM
The fault is a typical ******** fault. If its legal in your area you can fit a O2 spacer.
