jkane92 jkane92 is offline
Car: leon cupra
Default Help with logs. - 01-18-2019, 03:30 PM
Good Evening all,
I need some help with my logs. I managed to get 5 decent 4th gear logs today.
They are as followed:
-Standard (map 0)
-Fuel Bias 100 (Map 2)
- Fuel Bias 0 (Map 2)
- Posi tap discounted Fuel Bias 0 (Map 2)
- Posi tap discounted Fuel Bias 100 (Map 2)
The reason I took the posi tap off is that the one I'm using is a bit to small (24 to 26 gauge) and was unsure if it was making an electrical connect. What I did notice Is on standard AFR is pretty around 14 from start to redline, where as Fuel Bias at 100, It was dropping to 12.5 at stages and pulling a little bit of timing.
Car is completely standard apart from a turbo elbow. If anyone has some setting for map 6 please. Not sure what the safe boost is for a standard car.
Any help would be great.
Thank you
Default 01-21-2019, 10:41 AM
Originally Posted by jkane92
Good Evening all,
-Standard (map 0)
Thank you
Will respond to the email sent.
