Olli88 Olli88 is offline
Car: N54
Default JB4 reverts to Map 4 - 08-02-2018, 04:06 AM
I recently installed VRSF ******* *********, VRSF DCI, VRSF Charge pipe and Tial Q BOV. I also installed JB4. After install one of the coils went and the car went into limp mode, so i replaced all coils and plugs and that was solved.
Next the car keeps kicking up the Lambda Sensor code, i presume this is due to ******* *********, so just clear it on the JB4 and all seems ok.
For some reason JB4 still continues to revert me to MAP4 when ever i drive it a little bit aggressively, i have logged a couple of runs from last night, apologies they are not the longest as i don't have the roads nearby to WOT all through the gears and rev ranged.
I don't think the boost pressure is going up as high as it should either, the cars 2008 and only got 60k. I have had full service on it recently so everything is maintained and good to go apart from the map 4 problem.
( I am aware it moves to MAP 4 to protect the engine, i just don't know what its protecting it from )
Any help would be great
Default 08-02-2018, 10:32 AM
Looks like an O2 issue. Bank 2 Pre catalytic converter. Update your JB4 firmware as well.
Car: N54
Default 08-02-2018, 11:12 AM
Hello,
Thanks for the reply. I just installed the latest firmware for JB4 i also just put a MHD BEF on to see if this solved the problem.
Here are a couple of logs i have just done. Still the same problem though, i was thinking maybe the Lambda sensor has actually broken?? but i just wrote the error code off as being ******* *********.
Thanks again for any help
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 08-02-2018, 10:53 PM
Originally Posted by Olli88
Hello,
Looks like a bank 2/ AFR 2 issue.
You can try a lambda adaption reset, see if that helps, but looks like that bank sensor needs to be replaced
