Jon @ BMS's Avatar
Jon @ BMS Jon @ BMS is offline
Administrator
Default N54 N55 diagnostic code listing - 09-23-2008, 08:24 PM
Hi guys, just a quick reminder that if you need BMS technical support and purchased your product new from BMS or an authorized reseller you can also use our email support by emailing support@burgertuning.com.
For troubleshooting codes:
Code listing for N54 engines
Code listing for N55 & MINI engines
It is the sole responsibility of the purchaser and installer of any BMS part to employ the correct installation techniques required to ensure the proper operation of BMS parts, and BMS disclaims any and all liability for any part failure due to improper installation or use. It is the sole responsibility of the customer to verify that the use of their vehicle and items purchased comply with federal, state and local regulations. BMS claims no legal federal, state or local certification concerning pollution controlled motor vehicles or mandated emissions requirements. BMS products labeled for use only in competition racing vehicles may only be used on competition racing vehicles operated exclusively on a closed course in conjunction with a sanctioned racing event, in accordance with all federal and state laws, and may never be operated on public roads/highways. Please see http://www.burgertuning.com/emissions_info.html for more information on legal requirements related to use of BMS parts.
Default 03-30-2014, 08:32 PM
Directions for reading codes in dash using an E series JB4
To read codes via the in dash commands select menu 1 option 1 via your steering wheel controls.
1) The blinkers will flash twice and the speedo will move to indicate how many codes are stored.
2) The speedo will return to zero and begin reading out the codes. Each is a 4 digit number. Note the position of the speedo and reference the photo below to convert them to 0-9 and A-F code numbers. Those numbers can then be searched on this forum.
3) Each code will be followed by two flashes of the blinkers.
4) At the conclusion of the reading the blinkers will flash four times.
5) If the blinkers flash twice, then four times, with nothing in between, you have no stored codes.
Alternatively you can also read codes via the JB4 interface which will conveniently list the descriptions as well.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 05-29-2016, 04:38 PM
The F series jb4 OBD2 is able to read and clear all codes an obd2 scanner is able to right?
I'm just checking as my local tuner recommends a code scanner for ses codes, or maintenance codes the jb4 "cannot" read, or resetting service codes like oil change.
Not sure if that's legit interms of not being able to read all codes seeing that the jb4 connects via obd2 like the code scanner, but what about clearing codes?
Mods: Stock for now
Default 05-29-2016, 04:52 PM
JB4 reads/clears any DME faults.
bloked97one bloked97one is offline
Car: 335i n55 2011
Default 06-22-2016, 07:48 AM
I JON I DOWNLOAD THE CODE LIST FOR N55 IT'S TOO SMALL CAN YOU HELP ME OR SEND ME THE LISTING.
2C58 No Description Found
2C6F No Description Found
36C9 No Description Found
2C57 Reduced power mode / Boost disabled
3106 ******* ******** Installed
0000 No Description Found
THANK.
tp89 tp89 is offline
Car: 08 sgm 135i
Default 06-23-2016, 02:42 PM
Need some code help. I have a '13 X1 35i. With jb4, intake and chargepipe running 25% e85 mix on map5. Today I went full throttle (seemed to over boost) and they the check engine like came on and I can only max boost to 7 psi. The code is reading 2e0f. Any thoughts? Everything sounds and looks right.
Car: 08 sgm 135i
Default 06-24-2016, 01:51 PM
I went down to map2 and it's not doing it now. Could it be an over boosting issue with the autotuning map?
LECz3 LECz3 is offline
Question Fault Codes 310 & 2CA - 11-12-2016, 09:38 AM
Cannot find meaning for these two JB4 codes (310 & 2CA) for a 2009 135i.
Any help will be appreciated.
Lowon's Avatar
Car: Bmw M2
Default 12-12-2016, 04:38 PM
THANK.
You can zoom in, or use the PDF search function and type in the codes directly. Ctrl F and search.
Mods: Stock for now
1er///M 1er///M is offline
Default 09-19-2017, 03:14 PM
Terry,
How do you read codes when the speedo is in kph?
Thank you.
Jus2sikwitit Jus2sikwitit is offline
Car: E92 335i XDrive MSport Coupe
Default 07-10-2018, 06:40 PM
Driving today out of nowhere i get christmas light on the dash my radio navigation screen goes black my wipers turn on signal stays on...steering wheel is still responsive as well as brakes as normal and at the end of it all i get a coolant temperature symbol on my dash i pulled over shut the car off turned it back on and everything appeared to be normal but the jb4 pulled all these codes can someone help...i checked my coolant level it was fine my waterpump was running i tested it with the bleed procedure and even my charging system light went on but when i restarted the car it went away and hasnt come back on battery voltage has been going between 13.8 and 14.3 volts so all appears normal i just dont know what to make of all these codes the jb4 app gave me.
32d5
32d7
32d6
32d3
3886
3792
3847
378f
3446
00f1
All have no description next to them pleae help
Could a short circuit in the jb4 due to loose or dirty connection cause these issues? A lot of the codes dont even exist in the list for the n55 and the ones that do exist for the e92 n55 are for waterpump and battery voltage which after checking seem to be running fine. No lights voltage is where it should be waterpump is running fine thermostat is opening and closing. I just dont see how all these issues can occur out of nowhere when i have a less then 5k waterpump thermostat and battery on the car. Alternator and belt is new.
E92 LCI, N55, JB4, MHD W/BEF, CAI
